Drivers side motor mount
Old Jun 25, 2002 | 01:13 PM
88' CRX ZC's Avatar
Default Drivers side motor mount
If the drivers side motor mount is broken is there any thing i can do. Not to sure how it is broken cause its not out of the car. All I know is you can grab it and wiggle it.
Thanks.
I guess my question is does anyone make something to replace that mount or relocate it to acnother part of the motor and wrap around the side or something?
Old Jun 25, 2002 | 01:33 PM
Perfectionist's Avatar
Default Re: Drivers side motor mount (88' CRX ZC)
Check out hondaautomotiveparts.com or hparts.com for decent prices on OEM mounts. I would not try to rig up anything else to compensate for the broken mount. Just replace it with OEM.
Old Jun 25, 2002 | 01:36 PM
88' CRX ZC's Avatar
Default Re: Drivers side motor mount (Perfectionist)
Thank you!!
Old Jun 25, 2002 | 01:37 PM
YeuEmMaiMai's Avatar
if you are replacing a motor mount, make sure you use a hydraulic floor jack with a block of wood on the end to support the motor, makes taking that mount out a lot easier.......
Old Jun 25, 2002 | 01:46 PM
88' CRX ZC's Avatar
Default Re: Drivers side motor mount (YeuEmMaiMai)
But what if the mount is broken off the block?
Old Jun 27, 2002 | 10:37 PM
thisbugger's Avatar
you have to pull the motor out and weld it. make sure that the motor is completely stripped. but it's much easier to buy a new long block.
Boles28
Jul 8, 2018 01:17 AM
ShadyBAB
Dec 29, 2005 04:19 PM
