cutting bumpstop w/ shocks & springs installed
Old Jun 23, 2002 | 01:53 PM
sirminder's Avatar
Default cutting bumpstop w/ shocks & springs installed
well ive had my car lowered with some kyb agx and some skunk2 adjustables for quite some time now. but never did it occur to me to cut the bumpstop . anyhow, im gonna try and cut the bumpstops without dismounting the shocks and springs, just like the pic shows. im supposed to cut them in the middle correct? well let me know if im right or not. also, is there bumpstops in the back ones too? tia.
-does it matter which part i take off, the bottom or the top?
[Modified by sirminder, 10:55 PM 6/23/2002]
Old Jun 23, 2002 | 02:15 PM
LB CRX's Avatar
Default Re: cutting bumpstop w/ shocks & springs installed (sirminder)
yes cut it in the midddle and keeep the fat half. and yes there are bumpstops in the back
Old Jun 23, 2002 | 03:22 PM
bryant's Avatar
Default Re: cutting bumpstop w/ shocks & springs installed (LB CRX)
Old Jun 24, 2002 | 06:56 AM
Daemione's Avatar
Default Re: cutting bumpstop w/ shocks & springs installed (CR-X)
Just be careful not to score the shock piston when you're cutting them.
Are you actually hitting your bump stops? Skunk2's have some pretty stiff spring rates, I doubt you'd run into them very often - especially with upgraded shocks as well.
Tinoo
Suspension & Brakes
Oct 13, 2010 02:36 PM
ReVeNgEd-SoN
24
Jan 4, 2010 07:17 PM
DoubleOCivicSI80
Suspension & Brakes
Feb 24, 2009 11:42 PM
vpforeva
Apr 17, 2002 07:48 PM
Integra187
Jan 30, 2002 06:03 PM
