please help my 2000 integy a/c doesnt work anymore
Old Jun 26, 2002 | 05:51 PM
PurpleGsR00's Avatar
Default please help my 2000 integy a/c doesnt work anymore
well it keeps blowing out hot air.. what can i do to check????
Old Jun 26, 2002 | 06:23 PM
BreakStuff's Avatar
New User
Default Re: please help my 2000 integy a/c doesnt work anymore (PurpleGsR00)
If its still under warranty, pay the dealer a visit.. check the a/c valves and push in the schrader valve to see if the a/c system has any refrigerant, if it doesnt have pressure, then something could have been thrown into the a/c condensor and caused a leak, they could be weenies and try to charge you a diagnosis fee for this..
If it has pressure, then it is an electrical or mechanical failure and will most likely be covered under warranty..
Old Jun 26, 2002 | 06:32 PM
Default Re: please help my 2000 integy a/c doesnt work anymore (BreakStuff)
can you be more specif in terms of how i would go by doing so?
Old Jun 26, 2002 | 06:40 PM
BreakStuff's Avatar
New User
open the hood and find 1 of the 2 little blueish/green caps that cover the a/c schrader valves on the a/c lines.. remove cap and push the valve in (just like a bicycle tire,only bigger) if the system has pressure, then refrigerant should come out.. only do this for a second to determine..if you push the valve all the way down and nothing comes out,then you have no pressure and no refrigerant in the system...
Old Jun 26, 2002 | 06:44 PM
im gonna have to do that tommorow morning.. since its already dark outside..anyways.. if there is no pressure.. does that mean all i need is freon? or is there any way i can check for a leak?
Old Jun 26, 2002 | 06:50 PM
well i just went outside.. and it seems as if it has alot of pressure in it.. what do i do now? i checked both valves.. too
ohh by the way do the o2 sensors do anything for the ac?? cuz i have a testpipe with a checkengine light..
Old Jun 26, 2002 | 06:54 PM
BreakStuff's Avatar
New User
If there is no freon then chances are that you have a leak.. if you were to put freon in, it would just leak out again.. In your case checking for a leak is rather difficult.. your R134 refrigerant doesn't leave oily deposits like older R12 systems.., but you could look for a dirt buildup on any of the a/c fiitings or a/c condensor in front of the car.. find those caps and just follow the aluminum hoses throughout the engine compartment and do a visual inspection..but again it can be very hard to see if your not sure what you are looking for...
Old Jun 26, 2002 | 06:56 PM
i guess best bet is to go to the dealer!
maxboost10
13
Jul 26, 2022 02:22 AM
greenquark
Jul 15, 2016 03:54 PM
lmike6453
May 3, 2008 04:39 AM
graphic
Sep 24, 2004 08:17 AM
professorman
May 1, 2003 12:13 PM
