What is need to make CrvTec OR lsVTEC Reliable?
Old Jun 25, 2002 | 01:32 PM
g's integ's Avatar
Default What is need to make CrvTec OR lsVTEC Reliable?
Did the search button, still noting. Is there anything specific that is needed to make the CR/LSvtec conversion daily driveable. I am only asking because people are saying it can't be done which i doubt, but if it can be done is it gonna take alot of work and money.
Old Jun 25, 2002 | 05:07 PM
aeolus's Avatar
Default Re: What is need to make CrvTec OR lsVTEC Reliable? (g'sinteg)
Anything can be done...if you have some money...
Old Jul 8, 2002 | 12:34 PM
g's integ's Avatar
ttt
Old Jul 8, 2002 | 05:54 PM
dohcsideSi's Avatar
it will be reliable if the swap portion was performed correctly not some hack job. from a performance stand point it will be reliable up to 8k rpm if at the bare minimum you use arp rod bolts, have the botom end balanced, and use a crank gridle.
Old Jul 8, 2002 | 06:22 PM
h82lose's Avatar
Well you should reinforce that sucker with some crower or eagle rods and some je pistons. That should help out greatly and make sure you get a dohc oil pump that b18c1 is the best one.
Old Jul 8, 2002 | 06:56 PM
tinkerbell's Avatar
Default Re: What is need to make CrvTec OR lsVTEC Reliable? (dohcsideSi)
which ones? same as LS?
what about the head studs?
thanks,
t..
Old Jul 9, 2002 | 04:55 AM
Eddoes's Avatar
check out crvtec.com also the feb/march issue of hondatuningmagazine.com article called killer B. I have the swap u are talking about in my car using the jdm spec dohc vtec head with the b20b block no problems drive flat out every day, usually change at 8000rpm but ocassionally shift at 9000 rpm when the need arises.
Old Jul 9, 2002 | 07:26 AM
g's integ's Avatar
Default Re: What is need to make CrvTec OR lsVTEC Reliable? (Eddoes)
Thanks for the input guys!
Fugly123
Jun 2, 2012 01:57 PM
iamalex1212
Aug 21, 2008 12:45 PM
mountaindewguy
19
Jan 28, 2006 10:32 AM
rough_draft
Oct 31, 2004 03:32 PM
Hybrid CRX
Jun 23, 2003 10:05 AM
