need help about zex
Old Jun 24, 2002 | 05:31 PM
b18c-93's Avatar
New User
Default need help about zex
i have a 93 integra with b16a major bolt ons with a zex 55 shot and the zex cams i have running this set for the last 6 months at stock timming 16 deg well last night i tried a 65 shot and ran it 4 times and car started too act up really bad so i check my plugs and #1 had no tip it was gone so i was wondering if some one here can give me some tips and car was no leaning out , also have ngk racing plugs
Old Jun 25, 2002 | 01:04 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: need help about zex (93gsb16a)
car wasn't leaning out but you melted the plugs?????
What was your FPR set at?
What jets did you use?
Did you have the vacuum lines correctly installed?
Did one of the vacuum lines blow off?
Use stock plugs and retard igniton per ZEX instructions.
50 psi fuel pressure with vac. line disconnected from FPR.
Old Jun 25, 2002 | 01:28 AM
kinesistech's Avatar
What spark plugs are you using? DO NOT use any platinum plugs. They are stock for b16's. They have a higher operating temp and can induce detonation and melt the tip off your plugs in forced induction applications. Use NGK bkr7e stock number 6098.
I used to run a 70 shot on a sohc with those plugs. My friend borrowed it for a race in his SI and didnt change his plugs like I said, He burned exhaust valves.
Old Jun 25, 2002 | 08:06 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: need help about zex (kinesistech)
How does a spark plug burn exhaust valves??????
It doesn't!
Old Jun 25, 2002 | 10:12 AM
b18c-93's Avatar
New User
Default Re: need help about zex (Mista Bone)
i had my fpr set at about 45psi and no my vac was on my plugs have carbon from enough fuel and was running ngk r5672a-8 gaped at 36
Old Jun 25, 2002 | 10:14 AM
b18c-93's Avatar
New User
so what spark plugs should i really use and where should i gap them at and what timing should i have wright i have it set at 16 deg tdc
Old Jun 25, 2002 | 10:30 AM
builthatch's Avatar
MiG-21 superfan
no, but ultra high combustion temps or detonation will burn them right up with the quickness...also could get them red hot and soft, when your "wrong" plugs blows up, the lil plugs bits go right thru the valve after bouncing around and scratching your cylinder walls...many a 2/3 cylinder trip home from the track with my y7 taught me that lesson...
[Modified by builthatch, 2:34 PM 6/25/2002]
Old Jun 25, 2002 | 10:33 AM
builthatch's Avatar
MiG-21 superfan
bkr7e-11 NGk, gapped 32-35, with according to bone, 50 psi fp with hose OFF...always measure with hose off as to not vacumm fluctuations throw off readings. one prob with retarding timing is you then run hotter...try 14 btdc, 2 deg. retarded from your setting now. you are extremely lucky you did not burn up your exhaust valves...
Old Jun 25, 2002 | 01:54 PM
b18c-93's Avatar
New User
Default Re: need help about zex (builthatch)
what are the differences between rhe plugs i was using now to the one you say
lude98SH
Jun 24, 2007 02:39 PM
hondaeg8
Sep 26, 2004 11:46 PM
sting94112
Apr 18, 2004 04:26 AM
wickedxboi
Apr 12, 2002 03:27 PM
