My civic is loud as hell for no reason????
Old Jun 23, 2002 | 02:21 PM
oem's Avatar
oem
Default My civic is loud as hell for no reason????
I have a 97 Civic hybrid:
-swapped in 2000 civic si and everything.
-running a 98 ITR P73 ecu
-I/H/E
-test pipe
-ITR intake manifold
-B16A2 fuel pump
it's been running fine for 4 months till today. it's loud as hell just started today. The idle is fine, but it seems like there is an unsual backfire?
Old Jun 23, 2002 | 03:20 PM
bryant's Avatar
Default Re: My civic is loud as hell for no reason???? (utboi)
Are you running a chipped ECU? With H/E and test pipe your going to have a little back fire since there is nothing there to restric flow. Has the car been sitting, maybe take it around the block and see if it goes back to 'normal'. HTH
Old Jun 23, 2002 | 03:48 PM
Unsung's Avatar
Mine seemed to get louder too over time with my test-pipe and started back firing more... don't know why...
Old Jun 23, 2002 | 06:00 PM
oem's Avatar
oem
Default Re: My civic is loud as hell for no reason???? (JDM B-Series)
no..i know something is not right here. it's LOUD..... my car sounds like there's no exhaust system.
Old Jun 23, 2002 | 06:08 PM
YeuEmMaiMai's Avatar
i had the bolts between the header and my exhaust on my 92 sable 3.8L work their way loose and that shiet was loud loud loud. tightened all the exhaust bolts...problem solved
Old Jun 24, 2002 | 10:02 AM
oem's Avatar
oem
Default Re: My civic is loud as hell for no reason???? (YeuEmMaiMai)
problem fixed. 5 zigen exhausts suck. snapped at the resonator....it was only 4 months old.
Old Jun 25, 2002 | 08:00 AM
slowstang's Avatar
check for exhaust leaks, i had one on the mustang, right where the header and hpipe meet. it would backfire cus there wasnt enough back pressure.
Valenciabrihh
Mar 27, 2015 01:59 PM
Z.E.R.O.
Jan 26, 2009 01:43 PM
iiPancho
65
Nov 30, 2008 12:28 PM
jdmracer12
Oct 22, 2007 07:53 AM
1998teg
Nov 9, 2004 10:41 AM
