ECU Pins for map sensor and sensor ground
Old Jun 27, 2002 | 02:47 PM
legendboy's Avatar
Default ECU Pins for map sensor and sensor ground
I CAN"T BELEIVE IT! I own both the 96 service manual and the electrical troubleshooting 97 and no pinout of ecu connector!!! only engine harness side, no ecu pins. Anyways, I am Obd1, rs, i want to install my afc at the ecu instead of the map sensor, much cleaner install. anyone know which wires are
1. IG Wire
2. Air Flow Sensor Ground
3. Air Flow Input
I could use the wires from the map but i want a super clean install and all my instructions are in japanese! (air flow converter type II)
Old Jun 27, 2002 | 03:02 PM
legendboy's Avatar
Default Re: ECU Pins for map sensor and sensor ground (legendboy)
[Modified by legendboy, 9:36 PM 6/27/2002]
boostedblue23
Engine Management and Tuning
Apr 3, 2018 07:59 AM
Charlie Moua
Apr 18, 2012 07:57 PM
debogsr
Sep 30, 2005 10:33 AM
