engine lift wont lift...
Old Jun 26, 2002 | 07:24 PM
EGHatchy's Avatar
Default engine lift wont lift...
I was pulling a motor out today with my friends engine lift, then all of a sudden the lift stopped working. It just wouldnt go up any higher. Am I supposed to put more hydolic jack oil in it? and how do I do that?
Old Jun 26, 2002 | 07:38 PM
vhd's Avatar
vhd
Default Re: engine lift wont lift... (EGHatchy)
its probably at its max point of lift. shorten the sling/chains that is attach to the engine. if you have it too long, it'll limit the amount you can lift the engine up
Old Jun 26, 2002 | 09:26 PM
EGHatchy's Avatar
Default Re: engine lift wont lift... (vhd)
i dont think thats it, cause I lowered the lift, tried to raise it again, and no budge...
Old Jun 26, 2002 | 09:39 PM
Kamin's Avatar
is it adjustable? (meaning setting like 1ton, 1/2ton, 2 ton,)
you also might want to take the ram out and fully extend it then fully compress it.
mine was stubbron too but it worked after i set the ram to the correct position.
205gti
K Series
Dec 11, 2016 11:54 AM
MazworxRacing
Welding / Fabrication
40
Feb 4, 2011 11:45 AM
thegatekeeper14
Mar 31, 2010 11:19 AM
lilcasino
Oct 2, 2002 06:58 PM
