Port and Polish???????? questions!!!
Old Jun 26, 2002 | 03:29 PM
Acura_I-RS's Avatar
Default Port and Polish???????? questions!!!
ok, 1. what exactly do they do for a port and polish job, i have any idea, but i just want to know for my own good!
2. could i take my head into my local motor supply or napa, and have them do it?? or what? thanks in advance!
Old Jun 26, 2002 | 05:33 PM
EBP_SI's Avatar
Default Re: Port and Polish???????? questions!!! (Acura_I-RS)
this pretty much explains the whole process.
http://www.theoldone.com/articles/b16a.head/
Old Jun 26, 2002 | 09:01 PM
Tweakmeister's Avatar
if you're going to P&P you better know exactly what you want out of the motor. FI or NA? the above link is good...also check out the tech articles on http://www.hondavision.com
Old Jun 27, 2002 | 02:39 PM
Acura_I-RS's Avatar
Default Re: Port and Polish???????? questions!!! (Tweakmeister)
well, actually i am running NA right now, but plan on FI in the future, is there like something in the middle?
Old Jun 28, 2002 | 01:42 AM
kinesistech's Avatar
The only way to take full advantage of a port and polish is with a cam. You can actually hurt power by not adding a cam. Put that money toward your turbo fund. You'll be way more impressed with your turbo than you would a ported head on a non-vtec motor. Even though, vtec motors can run 11's without a port and polish, so dont be so sure you need one.
Old Jun 28, 2002 | 09:54 AM
Acura_I-RS's Avatar
Default Re: Port and Polish???????? questions!!! (kinesistech)
well, i just ordered a set of crower 404 cams for my ls, and i am orering the dual valve springs and titanuim retainers in a couple days also, and i plan on saving up for my turbo kit over the winter
Old Aug 8, 2002 | 07:54 PM
SoulSurfer's Avatar
Aftermarket cams arent good with a turbo.
Old Aug 8, 2002 | 08:02 PM
1 2 NV's Avatar
keep ur money, its not worth it with ur setup (which is basically nothing). if u were runnin 11s and needed that extra edge, then do it. until then, save ur money.
Old Aug 11, 2002 | 09:04 AM
Acura_I-RS's Avatar
Default Re: Port and Polish???????? questions!!! (hondaatwsu)
so its not really that much of a difference?? thats kinda what i thought also, cuz im not pushing like 350 HP through my head, so i wouldnt think the air would be slowed down that much in an otherwise stock head, but thatnks for your help man, later
Old Aug 11, 2002 | 09:09 AM
1 2 NV's Avatar
like i said, if ur lookin for that last extra ounce of power do it. but with the setup u have its not worth the $850 bones u will shell out for it. money can b better spent elsewhere. its all about hype. do u know how long stephan papadakis was runnin a non ported head on his turboed H22. i dont know exactly either but it was forever.
Old Aug 11, 2002 | 10:20 AM
piotrush's Avatar
Default Re: Port and Polish???????? questions!!! (LSDelSol)
Skunk2 makes cams specially designed for turbo motors
Old Aug 11, 2002 | 01:13 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: Port and Polish???????? questions!!! (piotrush)
P&P always is a good idea. simply to remove the casting imperfections. do it yourself, or pay someone to do it (but not 850!!) at least portmatch. even if you don't have a wilder cam. polish the cambers as well, again to remove the casting marks, but be careful around the valve seats.
and yes, a good turbo cam will always help your FI.
rdwaldo
22
Nov 14, 2006 08:34 AM
hondajav06
13
Jun 27, 2006 12:36 AM
93formula
May 10, 2005 04:27 PM
g5r
Sep 8, 2003 07:26 PM
JBk24crx
May 29, 2003 03:37 PM
