List of possibilities for burning oil
Old Jun 27, 2002 | 12:56 PM
Chairman Kaga's Avatar
Default List of possibilities for burning oil
This is probably pretty simple-
What are the possible causes for white smoke from the exhaust ONLY at 3500 rpm and above.
89 Prelude SI 2.0. Freshly rebuilt head. 128k mile. No other symptoms aside from a minor oil leak at the main seal.
Old Jun 27, 2002 | 01:55 PM
Chiovnidca's Avatar
Default Re: List of possibilities for burning oil (chairmankaga)
White smoke is usually caused by water and/or antifreeze.
Old Jun 27, 2002 | 02:00 PM
Default Re: List of possibilities for burning oil (Chiovnidca)
From the exhaust?
I guess I should have stated that. I can smell it too.
Rings?
Old Jun 29, 2002 | 09:31 PM
hondafrk's Avatar
water can only enter your engine via the Head gasket leaking, cracked head, cracked block or your fast idle valve leaking coolant into your exhaust.
Old Jun 30, 2002 | 01:53 AM
88_SC_CRX_Si's Avatar
New User
Another cause of white smoke is, running rich... Might take a look at your fuel pressure regulator. Mine will do it, if I set the fuel pressue up just a "tad" too high... hehehe
Old Jun 30, 2002 | 10:31 AM
Chiovnidca's Avatar
Default Re: List of possibilities for burning oil (88_SC_CRX_Si)
Running rich causes black smoke.
Old Jul 1, 2002 | 09:34 AM
Default Re: List of possibilities for burning oil (hondafrk)
This car has a brand new head/valve train. Think there could be a problem there? I've also noticed an oil leak, but I can't tell where it's coming from yet.
SOunds like trouble...
It only smokes when it's above about 3500 RPM.
Jackrabbit4
Jun 10, 2013 03:35 PM
oranginal
Apr 28, 2012 05:35 PM
Redprelude98
Nov 25, 2008 10:42 AM
vtec_ef8
Aug 9, 2008 07:04 PM
EF9 JAMS!!!
Aug 7, 2006 05:18 PM
