Steering Wheel Vibration - Please Help!!!
Old Jun 25, 2002 | 01:09 PM
dynamo's Avatar
Default Steering Wheel Vibration - Please Help!!!
Last saturday a friend and I replaced my left trailing arm due to the fact that it was bent. The install was fairly straight forward, and we were able to get the car together in one piece and running. However, because I messed with the toe compensator arm, I got a pretty bad vibration in the steering wheel, which I thought an alignment would fix.
Yesterday I had new tires mounted and balanced, and took the car in for an alignment this morning. Just got it back (they said my numbers are perectly within spec), and I still have pretty bad steering wheel vibration (not as bad as before but it is definitely there), from 70 - 85 mph. Anything before and after is absolutely fine, but during that particular interval the steering wheel starts shaking.
All suspension components seem tight and intact, nothing is loose. The tires are brand new, and were mounted and balanced yesterday - I checked and I am not missing any weights.
Can someone please tell me what else could potentially be causing this??? I am completely baffled, and it is extremely uncomfortable to drive around like this (especially with a commute like mine). Any ideas are greatly appreciated!
If it matters, the car is 2000 civic ex w/ rear disc brake conversion, 15" rota slipstreams with Falken Azeni Sports, GC + Koni Yellows, progress auto camber kit.
Old Jun 25, 2002 | 01:13 PM
YeuEmMaiMai's Avatar
Default Re: Steering Wheel Vibration - Please Help!!! (dynamo)
did you tighten the lugnuts all the way? i know it seems obvious but you would be suprised at some things over looked
Old Jun 25, 2002 | 01:17 PM
dynamo's Avatar
Default Re: Steering Wheel Vibration - Please Help!!! (YeuEmMaiMai)
They were put on yesterday, and the guys at the shop torqued them down - I watched them do it.
Old Jun 25, 2002 | 01:30 PM
Perfectionist's Avatar
Could be the new tires. My '02 CR-V had a hum or vibration at freeway speeds. The dealer finally took it to a shop that had a 'force balancer'. Three out of four tires were out of spec. (Honda allows 10lbs of force as the limit. Mine were 35, 25, 20 and 5.) Long story short, I got 3 new tires put on a new vehicle. So, don't rule out the tires.
BTW, a force balancer actually rolls the tire on a roller and measures the rolling force of the whole tire/wheel combo. It's the ultimate in diagnosing/balancing vibration problems.
DawgC2
Suspension & Brakes
12
Dec 11, 2011 05:01 PM
lildragon'07
13
Jun 2, 2010 08:31 AM
typer1982
Apr 29, 2009 09:09 AM
Essence of Chicken
Nov 13, 2003 09:21 PM
