Crank pullies?
Old Mar 28, 2002 | 03:19 PM
cool's Avatar
Default Crank pullies?
The search thread isn't working...
Can I use a B16 crank pulley in a B18C? Are they the same?
What about a H22/H23 crank pulley in a B18C?
Or should get an aftermarket lightweight one?
Old Mar 29, 2002 | 01:14 AM
ninesecrx's Avatar
Default Re: Crank pullies? (cool)
You can use a b16 crank pully on the gsr. They are the same thing. Do not use an aftermarket one. The honda pulley has harmonic balancing inside which the after market ones lack. Bad for the motor
Old Mar 29, 2002 | 02:58 AM
88_SC_CRX_Si's Avatar
New User
I don't think thats the case... There was some peeps installing them over at the Resource. After the install, they came back and posted "no vibration". Guess it depends, if you do get one and you pick-up a vibration get rid of it. Otherwise, I can't see anything wrong with using one. IMO
I tried using a HF on my Si, did not work. I picked up a vibration that would rattle your teeth.... BTDT
[Modified by 88_SC_CRX_Si, 4:01 AM 3/29/2002]
ilovemydc5
Feb 2, 2007 01:24 AM
importtuner07
Aug 19, 2006 05:06 PM
RAB
Oct 13, 2004 05:45 PM
NXSpoon
Jan 10, 2004 03:13 PM
1HotHonda
Jul 4, 2002 08:19 PM
