Ground Controls have to settle??
Old Mar 29, 2002 | 07:06 AM
Fuster_Cluck's Avatar
Default Ground Controls have to settle??
I am going to be installing the Ground Controls this Sunday along with the skunk2 front (skunk2 doesn't make the rear) camber kit and the washer / bolt trick in the rear.
Once I adjust the GC's after installing them do I need to let them settle for a week or so before getting an alignment?
I am hoping to get the alignment / camber kit adjusted on the monday (following day).
Thanks for any help on this!
Old Mar 29, 2002 | 10:40 AM
hybridreams's Avatar
Default Re: Ground Controls have to settle?? (LX98Civic)
Yesh - your car will drop another 1/4 - 1/2 inch after you install. Give it a week to be safe. May need to adjust front driver side level if you're a fat boy (will settle lower and make your car look slightly lop sided).
Old Mar 29, 2002 | 10:47 AM
mantic6t9's Avatar
Default Re: Ground Controls have to settle?? (hybridreams)
I always suggest getting your car corner weighted with coilovers.
Old Mar 29, 2002 | 10:51 AM
Default Re: Ground Controls have to settle?? (mantic6t9)
What does that mean?
Old Mar 29, 2002 | 02:35 PM
I Drive A Saturn's Avatar
corner weighting: adjusting ride height of each corner so as to shift weight for optimal balance
-jeremy
Old Mar 29, 2002 | 02:41 PM
Default Re: Ground Controls have to settle?? (I Drive A Saturn)
I'm not even sure if I know what that means.
Anyhow, I am just going to adjust the height give it 2 weeks, readjust and get the alignment done.....
Shop said between $69 & $89
nathchong
May 20, 2007 11:28 AM
hobbes2834
Apr 18, 2007 04:06 PM
pcapRsx
17
Feb 20, 2007 07:22 PM
Ratchback
Oct 5, 2004 10:19 PM
