Car not starting need help???
Old Mar 29, 2002 | 10:49 AM
BoM's Avatar
BoM
Default Car not starting need help???
h22a 89 civic
i really just need help on how to test the starter or ignition system.
we just fixed the fuel system, an injector was leaking we replaced the O rings.
now it won't start
how do i know if its the starter?
how do i know if its the ignition spark?
any helps
Old Mar 29, 2002 | 12:14 PM
EGh22aEG's Avatar
Default Re: Car not starting need help??? (BoM)
does anyone know?????????????????????
Old Mar 29, 2002 | 12:32 PM
BoM's Avatar
BoM
Default Re: Car not starting need help??? (esp169)
engine doesn't turn over.
starter clicks once
Old Mar 29, 2002 | 03:22 PM
SCsol's Avatar
remove the small single wire going to the starter. get a 2 foot wire stirp both ends and conect one end to the starter where you removed the wire and the other to the + on the battiery
Old Mar 29, 2002 | 08:51 PM
Spartanic's Avatar
Yeah that happend to me a while ago, I turn the ignition key and the engine rotates but doesn't start at all. It confused me for weeks until one day I found out that it was my TDC timing, it was all off! So I resetted the IGNITION and CRANKSHAFT timing to TDC and voila it worked!!!
Old Mar 30, 2002 | 05:18 AM
EGh22aEG's Avatar
Default Re: Car not starting need help??? (Spartanic)
its not even rotating......the only thing that happens is the fuel pump turns on then u hear a real slight clicking from the starter
Old Mar 30, 2002 | 05:32 AM
Spartanic's Avatar
Hmmm.....that happend to me also. It was the negative battey bolt that holds down the terminal, it was loose so every time I cranked my engine all I heard was this snappy noise and engine wouldn't start, so I just got a new Honda OEM ground bolt from the dealership and thought that it'll solve the problem, but strangly it didn't bolt in becuase the hole was so damn spreaded and loos that it didn't fit in properly anymore(hehe), so I had to used this other hole next to it(hehehehe) which fitted perfectly(hehehehehehahah!).
Old Mar 30, 2002 | 05:59 AM
EGh22aEG's Avatar
damn i wish it was that easy but i just got a new ground wire and hold.......and i checked it yesterday.......its fine
Old Mar 30, 2002 | 06:04 AM
Spartanic's Avatar
Hmmm.......is the battery fully charged? I'm geussing that is right? You check the alternator??? I had a bad alternator that also prevented the engine from starting and it also sucked up most of the battries juice.
Old Mar 30, 2002 | 06:36 AM
EGh22aEG's Avatar
i will have to check that but im pretty sure thats not the problem...because the lights and **** can all work but the engine doesnt even turn..
Old Mar 30, 2002 | 06:52 AM
B18C-RnVA's Avatar
New User
check the alternator...check the battery terminals, the wire hooked up to the starter from the battery.
cksnah252
12
Sep 9, 2014 07:51 AM
hondacivicowner
Nov 25, 2006 02:45 PM
nxstrikerxn
Feb 19, 2005 11:30 AM
BoM
Mar 29, 2002 04:13 PM
Phat Corolla
Jan 30, 2002 07:36 AM
