Inline fuel pump concerns
Old Mar 31, 2002 | 06:12 AM
Mikey3000's Avatar
Default Inline fuel pump concerns
my h22 is about to find it's home in my civic this week (FINALLY), and i know i'll need a high flow fp for when i go turbo. right now it's all motor and will be for a couple of months. so my question is, can i buy an inline fp now, instead of an in-tank fp, and regulate it with my fpr? will i run rich or what? btw, i still have stock injectors too.
Old Mar 31, 2002 | 06:19 AM
rainforest's Avatar
Default Re: Inline fuel pump concerns (Boss Hogg)
well it might all work out all the inlines are is the same as a in tank just inine with the fuel rail/filter. yeah you can regulate the fuel pressure but only up if you use a B&M/vortec non fmu style. you can get a inline wich runs high fuel pressure anyways then get a paxton fpr wich you can lower or raise. or you can cut a small hole in the return for the fpr and you can lower the base fuel pressure that way.
Old Mar 31, 2002 | 07:13 AM
Mikey3000's Avatar
Default Re: Inline fuel pump concerns (rainforest)
i have an SX fpr. i don't also don't understand a lot of what you're saying. (your typing).
[Modified by Boss Hogg, 11:14 AM 3/31/2002]
Old Mar 31, 2002 | 12:25 PM
Mikey3000's Avatar
ttt
Old Mar 31, 2002 | 01:56 PM
riceboy's Avatar
anyone know the PSI at which ohms the Walbro pump runs at?
SIK IN DA HED
Nov 12, 2003 09:37 AM
ATS*Mark
Nov 4, 2003 05:11 AM
HybridCoupe
Jul 6, 2002 03:48 PM
sushibug
May 6, 2002 05:50 PM
revhrdls
Sep 9, 2001 10:29 PM
