Tranny or clutch???
Old Mar 31, 2002 | 05:55 PM
Fr0m4311's Avatar
Default Is my Tranny or clutch dying???
I just need some help figuring out if it is my tranny or my clutch going. Ok. 1st, 2nd, 4th, and 5th gear go in great but 3rd grinds every time. Any help would be great. Thanks
[Modified by Mad_hatter, 3:31 AM 4/1/2002]
Old Mar 31, 2002 | 06:59 PM
rainforest's Avatar
Default Re: Is my Tranny or clutch dying??? (Mad_hatter)
do a search look up syncro's
Old Mar 31, 2002 | 07:03 PM
Pengo's Avatar
Pretty sure it's ur tranny. Some people say it's the third gear synchro and a trusted tranny expert has told me that a bad 1-2 shift fork is often the case. Best way would be to open that sucker up and find out.
Old Mar 31, 2002 | 07:20 PM
C1V1C's Avatar
tranny synchro fo sure
Old Mar 31, 2002 | 09:40 PM
3rdGteg's Avatar
Default Re: Is my Tranny or clutch dying??? (C1V1C)
Yep, 3rd gear synchro is bad.
Old Apr 1, 2002 | 05:43 AM
Fr0m4311's Avatar
Default Re: Is my Tranny or clutch dying??? (3rdGteg)
Should I get a new tranny or can it be fixed? About how much would it cost to get it fixed?
[Modified by Mad_hatter, 2:59 PM 4/1/2002]
Old Apr 1, 2002 | 07:55 AM
Kataku2K3's Avatar
Just rebuild it, you can do it yourself in a few hours. A synchro from the dealer will probably run around $150. If you have the dealer do it they'll charge you a grip. Have fun
Old Apr 1, 2002 | 08:14 AM
allenp's Avatar
Default Re: Is my Tranny or clutch dying??? (JDMspecEG6)
Just as a general observation:
If you're having trouble shifting into 1 gear, it's likely the trans (m/l synchro)
If you're having trouble shifting into ALL gears (suddenly) it's likely the clutch or clutch release system.
Old Apr 1, 2002 | 06:37 PM
Fr0m4311's Avatar
Where can I get a synchro besides a dealer (they want $216 for em). Is this a hard task to change out a synchro?
Old Apr 2, 2002 | 06:00 AM
Fr0m4311's Avatar
Will a 2000 civic Ex tranny fit on my engine?
Old Apr 2, 2002 | 08:39 AM
SCsol's Avatar
what kind of motor do you have? if you have a D motor the tranny will work fine!!!
Old Apr 3, 2002 | 04:32 AM
Mista Bone's Avatar
D Tranny Guru
synchros = $20 each, how many you need?
Old Apr 3, 2002 | 11:57 AM
Fr0m4311's Avatar
Default Re: Is my Tranny or clutch dying??? (Mista Bone)
The only synchros going are on third gear
Old Apr 3, 2002 | 11:29 PM
Mista Bone's Avatar
D Tranny Guru
first off, have you tore apart the tranny to see if it is the synchro or just blaming it like everyone else???
Ever see a bad 3rd gear synchro in a D series tranny??????
I haven't, but have sold plenty.
NO ONE abuses a D tranny more than me.
Old Apr 5, 2002 | 01:45 PM
3rdGteg's Avatar
Hey, what if your shifter won't go into 4th no more, there seem to be no slot for it anymore; just a wall that blocks 4th gear totally out.--Could this be a synchro too, or is it possibly the clutch gone bad?
Old Apr 5, 2002 | 09:48 PM
Mista Bone's Avatar
D Tranny Guru
neither, likely bent/broken parts in the internal shift linkage
Old Apr 7, 2002 | 09:31 PM
3rdGteg's Avatar
How would I go about diagnosing this problem? Where and what should I check for? (About my no fourth gear problem)
jordan_rael_420
Oct 18, 2010 04:57 PM
TurboGoKart
Jun 7, 2006 04:34 AM
ivanson
Mar 16, 2005 10:58 PM
epoxy
Jan 7, 2004 12:02 PM
