Emissions Help!!! Please take a second to see
Old Mar 28, 2002 | 11:14 AM
NAspirated's Avatar
Default Emissions Help!!! Please take a second to see
my setup is a crvtec 11.5 CR running fully built bottom end and head with a MUGEN program P28 chipped
my:
HCPPM is reading 500 supposed to be reading 100
CO% is supposed be at .50 the emission test is running at 9.50 and on idle it's 5.5
they didn't even continue from there!!!
would swapping out the P28 chipped mugen ECU to a stock P28 ecu help me pass?
I know that the mugen ecu dumps crazy fuel....
What else would help me out here manual fuel pressure regulator w/ fuel pressure gauge?
OH this is NJ by the way
Old Mar 28, 2002 | 12:39 PM
ALF's Avatar
ALF
Default Re: Emissions Help!!! Please take a second to see (NAspirated)
Whoa.
Yeah, try out the ECU swap...you need every ounce of help you can get.
Do you have any other mods? Did you heat your cat (ie redline) before going in? Or how about checking out your O2 sensor to see if it's fouled?
Old Mar 28, 2002 | 02:05 PM
b18bvtec4drteg's Avatar
Get rid of the ECU. If you have a VTEC controller.. lean the hell out of it helps too.
Old Mar 28, 2002 | 02:15 PM
fixhondas's Avatar
lower your fuel pressure- how is your NOx?
Old Mar 28, 2002 | 02:34 PM
SPOCK's Avatar
New User
Default Re: Emissions Help!!! Please take a second to see (fixhondas)
ADVANCE YOUR IGNITION TIMMING TOO. IT WILL HELP GET RID OF YOUR FUEL FASTER INSIDE THE COMBUSTION CHAMBER.
Old Mar 28, 2002 | 02:42 PM
fixhondas's Avatar
Default Re: Emissions Help!!! Please take a second to see (SPOCK)
advancing your timing will also increase NOx- which you do not want
Old Mar 28, 2002 | 05:30 PM
non-VTEC's Avatar
swap out the ECU and turn the timing back down to minium spec or less. you should pass with no problems then.
Old Mar 28, 2002 | 06:31 PM
NAspirated's Avatar
mods
skunk2 stage 2 cams
portflow retainers
ti titanium retainers
11.5 je pistons
ls crank mircopolished and balanced
eagle rods
block balanced and blue printed
stock injectors stock fuel rail
just bought a Manual fuel pressure regulator and pressure gauge
going tomorrow to check out the hondata system
gonna retard the timing and put in the stock p28 ecu
thanks everyone....
anything else I can do???
Old Mar 29, 2002 | 03:07 AM
88_SC_CRX_Si's Avatar
New User
Also, make sure your vacuum line to the MAP, is in good shape (if you have one)...
QUICKwitit
Feb 10, 2008 04:51 AM
jerbear!
Mar 26, 2006 11:28 AM
civicshark94
May 22, 2002 07:17 PM
SCsol
Apr 1, 2002 08:36 PM
JKim0901
Feb 21, 2002 07:42 AM
