code 17 vss
Old Mar 30, 2002 | 07:16 PM
HaUTSaauce's Avatar
New User
Default code 17 vss
I just threw code 17 (VSS). What do i need to check and how do i fix this? Also the same time i started getting this code my VTEC quit working!!!!! The sensor itself looks fine physically and is properly conected are there any fuses that could of shorted to cause this or what else should i check?
Old Mar 30, 2002 | 07:37 PM
clockworks's Avatar
Default Re: code 17 vss (HaUTSaauce)
What car?
Old Mar 30, 2002 | 07:49 PM
HaUTSaauce's Avatar
New User
Default Re: code 17 vss (clockworks)
crvtec ,ys1 tranny, but y should that matter?
[Modified by HaUTSaauce, 10:05 PM 3/30/2002]
Old Mar 30, 2002 | 07:53 PM
DR. ON POINT's Avatar
Banned
I believe u have to be going over 20 miles an hour or something like that for vtec to work. since u vss is no working it is not reading ur speed so no engagment. First unplug the sensor and clean it out with a Qtip. If that does not work unbolt the sensor and than clean it and put it back in. If that doesnt work put vaseline all over it. if that doesnt work buy a new sensor. If that doesnt work set fire to ur car and collect insurance money!
Old Mar 30, 2002 | 08:03 PM
HaUTSaauce's Avatar
New User
Default Re: code 17 vss (On Point EK)
i was thinking the same thing , thanks man
Old Mar 30, 2002 | 08:06 PM
HaUTSaauce's Avatar
New User
how much would a new sensor run by the way? does neone know?
Old Mar 30, 2002 | 08:25 PM
Kamin's Avatar
Yes you must be going over 10 MPH and the ecu has to get a CORRECT reading from the VSS. (meaning the spedo dosent jump all over like ive seen)
i dont know how much one runs but it might be 100~$
Also just double check alllllll the connection wires to the VSS. its located on the Firewall side of the transmission near where the differental is (where the axles plug in)
Old Mar 30, 2002 | 08:29 PM
HaUTSaauce's Avatar
New User
Default Re: code 17 vss (KAMiN)
all i see connected to the VSS is a connector going into the sensor and all of the wires seem to be fine.
Old Mar 30, 2002 | 08:33 PM
HaUTSaauce's Avatar
New User
if i do need to replace this sensor are they universal? tranny is a JDM lsd ys1. can i just go to Honda or Acura and get the part if so what year and from what car? Sorry for all the questions but i need to get this fixed
Old Mar 30, 2002 | 08:36 PM
SCsol's Avatar
in the manual it says to test the wires to the ECU if thats all fine then after cleaning the VSS it dont work test the VSS for OHM's and that stuff if still not working replace the the VSS still not working try another ECU
Old Mar 30, 2002 | 08:39 PM
HaUTSaauce's Avatar
New User
Default Re: code 17 vss (lowsol)
ok i will check it for OHM's i have already tried my friends ECU and that didnt fix it. But if i do need to replace it can i get one from Honda or Acura? because mine is jdm? just a question
Old Mar 30, 2002 | 11:26 PM
HaUTSaauce's Avatar
New User
up
Old Mar 30, 2002 | 11:37 PM
Katman's Avatar
YS1= cable type VSS.
is your speedometer working at all?
if not, check to see if the speedo cable is slightly popped out....if its popped out, that's probably why its not working.
The VSS is one of the main ingredients in allowing vtec to kick on. So no VSS, no vtec. Also, if you tampered with your gauge cluster at all, check that connection of the speedo on that end too..
Old Mar 31, 2002 | 07:05 AM
rainforest's Avatar
Default Re: code 17 vss (Katman)
katman is right check the cable for a snap or the acual vss for a crack. i have seen the vss's crack 2 times before and after that they wiont seat in right and you will be fuxored for life.
Old Mar 31, 2002 | 10:54 AM
allmotorEG-SI's Avatar
Default Re: code 17 vss (rainforest)
i was getting code 17 and it turned out the mechanic that put in my new tranny just didn't plug the speedo into the tranny all the way. it took me months to figure that out. what a dummy
Old Mar 31, 2002 | 11:04 AM
SiR Kid's Avatar
New User
If it's a cable VSS, it's all metal, and it uses a cable, no wires.
Here's a test for your cable/vss sensor.
Use a portable drill to spin the speedo cable and have a buddy sit in the car to see if the speedo moves. Try clockwise/counter clockwise, because I couldn't swear which one is the correct for positive speed readngs <not reversing>.
This will tell you if the cable/speedo works.
The only way to test the tranny's vss is to jack up the front end, and spin the wheels while watching the VSS inside with a flashlight. See if it spins while the tires are spinning.
NOTE: it will spin slowly inside the VSS, so watch closely, there's only a single keyway that you will see moving.
Hope this helps!
supra-n-civic
Jun 23, 2009 07:01 AM
u2civic1
17
Aug 10, 2004 07:15 PM
mattt
Nov 26, 2002 08:03 PM
HaUTSaauce
Mar 30, 2002 07:12 PM
