Distrubutor install
Old Mar 28, 2002 | 03:00 PM
mantic6t9's Avatar
Default Distrubutor install
Is it neccesary to find TDC when replacing the would distributor housing with a new one? Can just take note where the old distributor was, install the new and check the timing? Any help would be cool . BTW this is on a d16z6 sohc engine.
Old Mar 28, 2002 | 03:16 PM
psi420's Avatar
Default Re: Distrubutor install (mantic6t9)
Pull the old one off, slap the new one on.
The cam is keyed, dist will only go on, one way.
Old Mar 28, 2002 | 05:43 PM
mantic6t9's Avatar
Default Re: Distrubutor install (psi420)
hmm... anyone else?
Old Mar 28, 2002 | 05:53 PM
EE_Chris's Avatar
tis' the truth (99 CX...just got curious while doing a cap & rotor job, so I took it off to see)
[Modified by EE_Chris, 2:54 AM 3/29/2002]
Old Mar 28, 2002 | 06:00 PM
mantic6t9's Avatar
Default Re: Distrubutor install (EE_Chris)
what about timing will that change?
Old Mar 28, 2002 | 11:04 PM
RR98DX's Avatar
yes, use a light.
Old Mar 28, 2002 | 11:06 PM
t's Avatar
t
Timing will change, but if you put it back close to where it was before you took it off, timing shouldnt change but a degree or so.
Old Mar 29, 2002 | 01:01 AM
ninesecrx's Avatar
Just eyeball where the other dist. was. Hondas adjust automaticly with the ecu anyways so if your a little off, you will not hurt anything. The only real way to do the timming is with a light though. And yes, they only go on one way.
Old Mar 29, 2002 | 06:51 AM
mantic6t9's Avatar
Default Re: Distrubutor install (ninesecrx)
Ok cool. I guess i'll install it and then drive up to autozone and set the timing there since i don't have a timing light. Thanks for all the help. One more thing, when i disoconect the battery will there still be power stored in the coil? if so how would i ground it? I don't want to get shocked.
Old Mar 29, 2002 | 10:45 AM
mantic6t9's Avatar
I got it installed and everything seems to be cool. I turned it untill it smoothed out, about where the old one was. I'm still going have my timing checked. Since i'm doing this should i go ahead and have it advanced a few deg? I have: aem intake, greddy header, and apex n1 catback. Would i benifit any from this? Thanks.
UR2NOZ
Jun 6, 2010 06:02 PM
LudeCris
Feb 6, 2006 05:33 PM
LoseRPunKx182
Jul 16, 2005 09:10 PM
Arsenal
Apr 9, 2005 10:20 AM
abstractj
Sep 25, 2003 09:57 AM
