i fu-ed up somthing please help
Old Mar 31, 2002 | 12:26 AM
rob1208lv's Avatar
Default i fu-ed up somthing please help
I have a 94 integra ls with turbo drag 3 kit... i was racing a crx on the freeway, and my car didnt sound right... i pulled to a gas station poped the hood and this is what i sall... oil everywere, leaking from the back of the head, coming out the breather filter boiling out the breather... my boost gauge reads 15 at idle... and not sure if i felt air comming from the turbo manifold, or if that was just the fan.... also the car was smoking but im not sure if its from burning oil on the engine or somthing else... its sounds really bad... could it just be a head gasket????? help me pin point it please
Old Mar 31, 2002 | 04:39 AM
bseriesrex's Avatar
Default Re: i fu-ed up somthing please help (rob1208lv)
Yeah sounds like you definately took out your head gasket to me and if its coming out the breather then you definately have a problem.I haope you didnt just bolt a turbo onto your stock engine as sooo many people do then ask why did it brake.If you want a turbo on your honda/acura then goto honda and ask for the one they put on their turbo hondas.Then you might rethink turbo since honda didnt produce one for their cars.
Sory to hear what happened to you guy.That is why I keep em all motor.
Old Mar 31, 2002 | 06:12 AM
rainforest's Avatar
Default Re: i fu-ed up somthing please help (bseriesrex)
look at the coolent if its sluggy and black your headgasket is gone. als white smoke form the tail pipe. there is the posibillty that you have a bent valve or just your spark plg gaskets are shot. check the gaskets and do a com[pression test or look at the color of smoke that your cars exhaust is spitting out.
Old Mar 31, 2002 | 06:43 AM
mantic6t9's Avatar
Default Re: i fu-ed up somthing please help (rainforest)
I agree sounds like you have blown your headgasket. Like was mentioned check your coolant to see if there is any oil in it. Good luck man.
Old Mar 31, 2002 | 10:06 AM
rob1208lv's Avatar
Default Re: i fu-ed up somthing please help (mantic6t9)
replaced the head gasket, still runs choppy what else could it be
Old Mar 31, 2002 | 10:15 AM
Kamin's Avatar
explain choppy.
do a compression test and while the plugs are out inspect them.
Old Mar 31, 2002 | 10:28 AM
rob1208lv's Avatar
Default Re: i fu-ed up somthing please help (KAMiN)
boost gauge reads 15, and by saying choppy i mean the idle is real wacked....plugs look ok what do i look for???? how do i do a compression test
masontaylor94
Aug 21, 2017 04:52 PM
Cummins4LF
Sep 11, 2015 07:12 PM
drift4food
Apr 8, 2005 05:07 PM
vteccivicracer03
Nov 26, 2003 11:01 AM
rob1208lv
Apr 1, 2002 12:54 PM
