WHY ?? is it pulling 2 the side ?
Old Mar 29, 2002 | 07:29 PM
Zeus Zore's Avatar
Default WHY ?? is it pulling 2 the side ?
when i hit the gas it pulls the the right... when i let go it goes stright !!! ??
what the hell it wrong ?!?!
plz help !?
Old Mar 29, 2002 | 07:54 PM
Spartanic's Avatar
Default Re: WHY ?? is it pulling 2 the side ? (Zeus Zore)
Man, you probably have bad suspension alighnment which could be cured at any shop with the proper alighnment equipment. Its either that our your suspension bushings are so worn that the car pulls to right or left when the gas pedal is pressed.
Old Mar 29, 2002 | 08:06 PM
hatchy's Avatar
Check your wheel bearings. I had the same problems until I swapped the steering knuckle out... Now the only problem is the excessive torque steering.
Old Mar 29, 2002 | 08:14 PM
Zeus Zore's Avatar
Default Re: WHY ?? is it pulling 2 the side ? (hatchy)
thx.. but ...
???Now the only problem is the excessive torque steering. plz explain..
and
wheel bearings = .. ??!! where on the suspension ??
Old Mar 29, 2002 | 08:17 PM
Spartanic's Avatar
Lemme tell ya that removing the wheel bearings is gonna be a biatch. You'll probable end up cursing, bleeding or ending up with a terribly broken nail. It take time and patience. The bushings are located on all joints and ends(I think) on the suspension, but hey if your lucky it could just be a bad suspension alighnment. Take it to the shop.
Old Mar 29, 2002 | 08:21 PM
Zeus Zore's Avatar
Default Re: WHY ?? is it pulling 2 the side ? (Spartanic)
thx
yes i hobe that it is just the wheel alighnment thats fucked...
i know that this could do it !!! but whanted 2 know what else good be wrong !!
Old Mar 30, 2002 | 12:00 AM
wessieball's Avatar
Ever since I lowered my car, it has pulled to the right, regardless of an alignment. I just lived with it until I found out the other day that it's caused by torque steer. The only thing the mechanic could suggest is to put stiffer engine mounts in which isn't gonna be easy. It's something I've learned to live with.
Old Mar 30, 2002 | 12:53 AM
turbo_ef9's Avatar
Default Re: WHY ?? is it pulling 2 the side ? (wessieball)
my cousins car does that.. it's got a ITR lsd trans and when we gun it it pulls to the right... *sigh.. oh wells.. it's fast..
Old Mar 30, 2002 | 06:09 AM
Zeus Zore's Avatar
Default Re: WHY ?? is it pulling 2 the side ? (b16_ef)
ohh ok understand that part now THX !! so it is kinda normal with TQsteering !?!? what maes it do this ??? and why do it pull 2 the right !!? loss of grip !?!
BiG ChOr!Zo
44
Sep 11, 2011 10:23 AM
TOO MUCH TORQUE
Suspension & Brakes
14
May 20, 2009 03:42 PM
RED_90TEG
10
Jul 16, 2007 06:50 AM
ef9robert
Mar 22, 2006 02:49 PM
Toptul_Honda
28
Jan 29, 2003 06:15 PM
