throttle body
Old Mar 30, 2002 | 10:52 PM
evil_elmo's Avatar
Default throttle body
can you bolt and use a B16a throttle body and intake manfold on a B18c???
Old Mar 30, 2002 | 10:56 PM
evil_elmo's Avatar
Default Re: throttle body (evil_elmo)
and forgot to ask, if you can use a B16a throttle body and intake manfold will my factory B18c ECU run it???
thanks for your help guys
Old Mar 30, 2002 | 11:45 PM
Katman's Avatar
1) yes and no.
Yes you can use a 92+ B16A TB on a GSR intake manifold, but you need to use a GSR's throttle cable bracket on the TB itself.
no, a B16A intake manifold will NOT bolt up to a GSR head. The flange bolt holes are in an offset pattern and will not work. you're best bet is getting a Skunk2 intake manifold for the GSR head.....now that bolts right up and replaces the dual-butterfly 'snail shell' looking GSR intake manifold.
3) yes, you can use your GSR ecu with a single-butterfly intake manifold also. But it's best to eventually get it reprogrammed with a single-butterfly program....especially if you upgrade your camshafts.
fyi -- a single butterfly manifold is any of these intake manifolds: B16A/B17A/B18C-R/ Skunk2 /LS
[Modified by Katman, 12:46 AM 3/31/2002]
Old Mar 31, 2002 | 12:32 AM
evil_elmo's Avatar
Default Re: throttle body (Katman)
Katman you are THE MAN!!!!!!!
THANK YOU for your help
Old Mar 31, 2002 | 12:50 AM
evil_elmo's Avatar
sorry katman i have another question for ya
which is better skunk2 intake manifold or teg Type R???
Old Mar 31, 2002 | 03:32 AM
canuck-mx6's Avatar
The skunk 2 is a copy of the type R. It has a different hole patter so that it bolts to the GSR head.
Old Mar 31, 2002 | 11:37 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: throttle body (canuck-mx6)
Skunk2 also makes the ITR copy that fits the ITR.
They are about the same. The only reason to get the Skunk2 for the GSR is to use the large runners and plenum.
Old Mar 31, 2002 | 05:23 PM
evil_elmo's Avatar
Default Re: throttle body (B18C-EJ1)
so does a factory Teg Type R intake manifold fit a normal GSR?
Old Mar 31, 2002 | 08:04 PM
B18C-EJ1
Guest
Posts: n/a
No, as explained before, the GSR is different bolt pattern.
Old Mar 31, 2002 | 10:48 PM
Katman's Avatar
yeah the Skunk2 manifold for a B16A/ITR/CTR head is a waste of money...you're better off buying a real OEM 'R' manifold. and again....the skunk2 manifold for GSR head is specifically made for the GSR head because of the different flange bolt pattern.... so an OEM ITR manifold will not bolt up to a GSR head....sorry.
Old Apr 1, 2002 | 01:25 AM
evil_elmo's Avatar
THANKS everyone for your help :D
Old Apr 1, 2002 | 06:39 AM
bigblockEG's Avatar
I had the Skunk2 mani on my old gsr and I was very happy with it. I didnt even have the program for the different config and I gained 3-4 midrange hp and 8ft/lbs midrange torque. I liked it...
silos
Apr 25, 2003 06:50 AM
