CEL flashes during driving!?
Old Mar 31, 2002 | 09:37 PM
3rdGteg's Avatar
Default CEL flashes during driving!?
I just through on a Mugen p28 ecu along with an obd2-obd1 harness and everything seems to function correctly except that there's the annoying CEL that keeps flashing "8" times and then pauses then again everytime I drive the car. My jumper is not even connected to check codes. What could be the problem??
Tia.
Old Apr 1, 2002 | 12:02 AM
Katman's Avatar
Default Re: CEL flashes during driving!? (3rdGteg)
Tia.
Code 8 = Top Dead Center sensor
have had any mods done to your motor at all, camshaft or cranktiming wise? if not, I bet the ECU jumper is at fault.
Who makes the ECU jumper you have?
[Modified by Katman, 1:03 AM 4/1/2002]
Old Apr 2, 2002 | 10:12 AM
3rdGteg's Avatar
Default Re: CEL flashes during driving!? (Katman)
Yeah, I'm running crower 63402's with my ignition timing retarded way back since my head was milled way past its limit mark.
The jumper on the ecu was just a wire being soldered into J1 location in a p28 ecu. I don't think it's the jumper because if it's not appropriately connected, then the chip would not take effect right?--the vtec engagement and everything works, except that code flashes all day long.
Old Apr 2, 2002 | 03:04 PM
Katman's Avatar
hah..no man..i'm not talking about the J1 jumper on the motherboard. I'm talking about the ecu OBD2-OBD1 JUMPER harness. That itself, could possibly have something wrong with it, hence the code 8 check engine light..
Old Apr 2, 2002 | 05:45 PM
3rdGteg's Avatar
Oh sorry Katman, I made the jumper myself from Hx Guy's pinouts list. What wire do you think I left out or twisted??
Thanks for the replies Katman.
Old Apr 3, 2002 | 01:58 PM
3rdGteg's Avatar
Katman? Anyone?
Old Apr 3, 2002 | 02:48 PM
Katman's Avatar
i have no idea....
its' hard to diagnose your problem over the internet. I'd have to see the wiring in person.
[Modified by Katman, 3:49 PM 4/3/2002]
Old Apr 3, 2002 | 07:52 PM
3rdGteg's Avatar
Okay thanks anyway, I guess I'm just stuck w/ this annoying flashing cel; I wonder if my ecu is on "Safe Mode" with this problem.
Old Apr 4, 2002 | 10:18 AM
Katman's Avatar
depending on what code its throwing, its safe to assume you're in safe mode. Usually when the check engine light comes on ...that's a red ***..err flag for safe mode.
350znal
Engine Management and Tuning
Feb 25, 2011 01:49 PM
rick_rabies
Aug 24, 2009 06:22 PM
TurboBA8
Feb 20, 2007 07:25 AM
acuracy r
Jan 3, 2006 05:56 PM
splitime
Sep 6, 2002 10:21 AM
