need help with speedometer problems
Old Mar 26, 2002 | 07:35 PM
Looose_R's Avatar
Default need help with speedometer problems
my speedometer hasnt worked since my clutch install. the speedo never worked from the minute i started driving. CEL says code 17 which is the VSS(vehicle speed sensor) we replaced the speed sensor with a known working unit and still it wouldnt work. so my question for you guys is their any way tthe shop fucked up the speedo drive gear? thats the only thing i can think of. anyone have any sugestions?
btw, CEL only comes on during hard driving, and my clutch master cly seems to be making a strange whining noise when the pedal is depressed all the way.
_thanks in advance,
Old Mar 27, 2002 | 10:51 AM
Looose_R's Avatar
Default Re: need help with speedometer problems (b20bastard)
ttt
Old Mar 27, 2002 | 01:09 PM
tinkerbell's Avatar
hmmm, dunno, maybe the sensor is not sitting correctly?
have you removed it to check its still ok? if you replaced it, was it with a new one?
while its out - check the drive gear...
t..
Old Mar 27, 2002 | 04:49 PM
Big B's Avatar
Remove the speed sensor and make sure that the little drive shaft thingy is still in between the sensor and drive unit. if its there and you know that the speed sensor is good start checking the connector and wires for damage. They could of left it connected when removing the trans and dislodged the pins.
Kris05TSX
Transmission & Drivetrain
11
Jun 25, 2024 10:04 PM
Renhard
Sep 11, 2018 08:31 AM
b frisco
Mar 5, 2008 10:11 PM
aziaticvang
Jan 13, 2008 06:35 PM
nenacivic23
Aug 30, 2004 03:18 PM
