USDM B16 vs.JDM B16???
Old Mar 31, 2002 | 09:13 PM
RedDragon's Avatar
Default USDM B16 vs.JDM B16???
What are the differences in these two engines(other than the red valve cover)???
Old Mar 31, 2002 | 09:26 PM
rainforest's Avatar
Default Re: USDM B16 vs.JDM B16??? (RedDragon)
yeah i cut and pasted this
cast aluminium oil spray bars on the first gen while the later generation ones are made of extruded aluminium.
Old Mar 31, 2002 | 11:33 PM
Katman's Avatar
Default Re: USDM B16 vs.JDM B16??? (rainforest)
it's a little more than just that..
Redragon..
To begin with are you asking aboout Hydro B16A's or the Cable type? cuz US Honda never released the cable type B16A in the states....ever. We only saw the beginning of B-series Vtec engines in the 1992 Integra GSR (B17) which did have some parts from a cable type B16A, but was not 1.6L. Now, if you're asking in regards to only the hyrdo-type B16A's aka 92+ B16A's then here's what the differences are:
1. ecu
the JDM 92+ ECU is the small type and is probably programmed with a slightly bit more aggressive fuel/timing maps than the US version found in the DOHC DELSOL.
2. transmission.
The JDM 92+ B16A Hydro tranny has an optional LSD, unlike the US version which doesn't have that option. The gear ratios are exactly the same, although, I've found that the US 92-95 B16A tranny has a tighter 1st gear....but soooooooo what!
3. throttlebody.
JDM VS. US B16A throttlebodies are the same in diameter, but what differs is the MAP sensor. the JDM version doesn't have a MAP sensor on the TOP of the TB like a US B16A would have. that's it...nothing more.
4. Pistons.
92+ JDM B16A's have a 'P30' piston which puts out 10.4 compression ratio. ALL US B16A's have a 'PR3' piston which is 10.2 compression ratio. Why we don't get the P30 piston still mystifies me, but I'm sure it has to do with some bullshit revolving around politics.
The valvetrain is exactly the same, oil spray bars are billet aluminum design, valve springs, valves, cams, all the same between US and JDM versions of the 92+ B16A.
.....that's about it. So, the only real big difference between a US and JDM 92+ B16A engine is the JDM LSD tranny and the P30 pistons.
[Modified by Katman, 12:37 AM 4/1/2002]
Old Apr 1, 2002 | 06:44 AM
RedDragon's Avatar
Default Re: USDM B16 vs.JDM B16??? (Katman)
Katman,
Thanks for the reply.I haven't been able to get a straight answer from anyone.I printed out your response so I can refer back to it later.I'm trying to learn as much as I can about these engines.I have a 2000 Civic Si and was curious as to the differences between the engines produced here as to Japan.I want to build my Si to J-spec and was coming up short on info....
Thanks again for the help.
RedDragon
Old Apr 1, 2002 | 08:45 AM
Katman's Avatar
coo..
well all you really have to do to match a JDM B16A, is basically swap your pistons out and for some P30 pistons and get a hold of a Y21 or S4C LSD tranny..
Old Apr 2, 2002 | 08:23 PM
StorminMatt's Avatar
I have also heard rumors that the cams are different as well. The USDM cams are not as good as the SIRII cams. But they are better than the SIRI cams.
Old Apr 3, 2002 | 01:59 AM
Katman's Avatar
Default Re: USDM B16 vs.JDM B16??? (StorminMatt)
well as far as 89-91 vs. 92+ B16A cams yes.... the 92+ have a better profile. But as far as JDM vs. US 92+ B16A cams they are the same.
Old Apr 3, 2002 | 05:29 AM
SpooN Man's Avatar
1 gen cams suck
Old Apr 3, 2002 | 12:21 PM
Katman's Avatar
Default Re: USDM B16 vs.JDM B16??? (SpooN Man)
1 gen cams suck
...it seems the 23rd century "sucks" just as bad too!
check it out:
http://www.theonion.com/onion3812/ti...ling_teen.html
Old Apr 8, 2002 | 10:08 PM
Soku1kcivic's Avatar
What about the mounting is it the same as the USDM 00Si against the JDM B16A second gen
THanks Katman
Old Apr 8, 2002 | 11:39 PM
Kamin's Avatar
Default Re: USDM B16 vs.JDM B16??? (Soku1kcivic)
katman u ******* rule dude
lol
Old Apr 9, 2002 | 09:16 AM
Katman's Avatar
THanks Katman
yes, same mounting. You'll have to reuse your civic's 'bridge' mount on the timing belt side though.
this thing:
Old Apr 9, 2002 | 04:35 PM
Katman Do i use a US 96-98 integ or delsol B series distrubutor for my B16A because the 96 is obd2 and the motor is obd1 what should i do use the obd 1 or 2 wires because my obd2 has vtec wiring set??
THanks Katman
Old Apr 9, 2002 | 10:46 PM
Katman's Avatar
THanks Katman
uhh im confused a little with what you're asking. If I'm reading you right, you own a 96-98/OBD2 civic or integra right? if so, then yes, its best to get an 96+/OBD2 B-series distributor and if you don't want to wire your car, get a hold of a 96-98 EX coupe engine harness if you own a 96-98 civic or a 96-98 GSR engine harness if you own an integra. You'll still have to wire up vtec from the ECU to-shock tower if you own an integra though. You should already have a 4-wire 02 if own an integra also.
Old Apr 12, 2002 | 09:10 PM
THanks i have finish my swap in my EK
Tebownerb16
Transmission & Drivetrain
Oct 3, 2016 02:03 PM
PRLSV
Jul 2, 2012 01:52 PM
Junkyard
May 14, 2009 09:22 PM
SiR Inspired ED7
21
Jan 4, 2009 03:50 PM
forever slow EG6
10
Aug 16, 2002 12:45 PM
