Auto won't shift at the right point! PLEASE HELP!
Old Mar 27, 2002 | 09:08 PM
KoRE's Avatar
Default Auto won't shift at the right point! PLEASE HELP!
Hi,
my automatic shifts at 7500 when i floor it when it's supposed to be shifting at 6800 i'm wondering what the problem is? and how to fix it thank you.
Old Mar 27, 2002 | 09:17 PM
BoM's Avatar
BoM
Default Re: Auto won't shift at the right point! PLEASE HELP! (KoRE)
lol, the speedo is off just a tad, and maybe its slipping.
how many miles on that?
Old Mar 27, 2002 | 09:22 PM
KoRE's Avatar
Default Re: Auto won't shift at the right point! PLEASE HELP! (BoM)
it a 97 integra had a trans rebuild at 35-36k now has 44k
Old Mar 27, 2002 | 09:24 PM
KoRE's Avatar
i'm pretty sure the speedo is off about 2mph but i thoguht that was normal cause my friends is like that but his is fine.
Old Mar 28, 2002 | 08:30 AM
HumanResource's Avatar
Default Re: Auto won't shift at the right point! PLEASE HELP! (b19coupe)
Might hafta change the ATF inside if you haven't done so in a while.
Old Mar 28, 2002 | 08:44 AM
92sleepR's Avatar
New User
I don't know nutthin bout no automatics Miss Scarlet!
Sorry,... I just couldn't resist.
I't might be something wrong with the VSS or tach signal. Does the speedo read properly? It could also be a problem with the valve body of the transmission but like I said above, i really don't know jack about automatic trannys. a cheap solution you might try is flushing the trans and putting new fluid in.
Mike
Old Mar 28, 2002 | 05:48 PM
b19coupe's Avatar
To adjust the shift points on an automatic transmission you need to adjust the throttle pressure cable to the transmission. More slack = earlier shift points and less slack = later shift points. Note : some later model Honda/Acura transmissions are completely electronic and use the TPS signal to choose shift points. If you have a cable from the throttle body to the transmission, then you have the option of adjusting it.
Old Mar 31, 2002 | 09:16 PM
KoRE's Avatar
i tried changing the fluid b4 but that didn't work
hmmm if i took it to honda or acura and just asked them to check the cables would they charge me anything?
wagovan guy
Dec 28, 2014 07:12 PM
SnoFox4
Jun 4, 2011 11:25 AM
Del_SouL
Mar 6, 2005 11:41 AM
JMD
Oct 21, 2004 02:15 PM
