Scratched Pistons?
Old Mar 30, 2002 | 01:31 PM
Integra91LS's Avatar
Default Scratched Pistons?
After pulling the head off my car i noticed that on the top of one of the pistions there was a nick in it. Not deep but there was an abbrasion there. It was smooth but you could tell it wasnt supposed to be there. Is this bad for the engine and should i get new pistons or am i just a lil over nervous about it?
Old Mar 30, 2002 | 02:29 PM
Default Re: Scratched Pistons? (Integra91LS)
anyone?
Old Mar 30, 2002 | 03:24 PM
non-VTEC's Avatar
how did the piston get scratched? did somthing enter the combustion chamber? is there a scratch/nick on the cylinder head as well.
it could just be a casting mark from when the piston was made??
Old Mar 30, 2002 | 03:43 PM
Default Re: Scratched Pistons? (non-VTEC)
no i had the head resurfaced so i dont know... and its more or less a smudge.. its real smooth.. not jagged.. not a casting mark.. is this damaging to engine? its very small , noticeable but small
Old Mar 30, 2002 | 03:52 PM
non-VTEC's Avatar
it's probably a casting mark........if somthing hit it then it would be jagged.
maybe you should replace all 4 pistons while you have the head off........a set of B16 pistons arent very expensive.
Old Mar 30, 2002 | 04:36 PM
I (not a mechanic) heard that replacing pistons is a bitch to do. Im doing most of the work with a friend of mine whom is a mechanic and thasts what he said.. dunno
Old Mar 30, 2002 | 04:38 PM
non-VTEC's Avatar
it can be a bitch to do but it takes just a couple more hours of work. plus a trip to the machine shop to have the old pistons pressed out and new ones pressed in........it can be worth it though?
just a thought...
Old Mar 30, 2002 | 04:52 PM
and where can i get a decent set of pistons from?
Old Mar 30, 2002 | 05:08 PM
non-VTEC's Avatar
the honda dealer will sell you B16 pistons for about 40-60 bucks each. not including new rings.
Old Mar 30, 2002 | 06:48 PM
What happens to the engine if a little bit of really fine carbin gets inbetween the piston and the block itself.. in that sleeve.. will that do damage?
Old Mar 30, 2002 | 06:54 PM
non-VTEC's Avatar
rotate the crank so the piston moves down a bit and clean it up...........it shouldent really do anything though......
Old Mar 30, 2002 | 08:49 PM
SCsol's Avatar
if your buying new pistions and your replacing all of them it will be checper and smarter to replace them with ITR pistions you will lose a little comperssion ratio but better pistions at a cheaper price
TravisBiggie
May 24, 2012 12:58 PM
Longbow
21
Oct 23, 2010 12:41 PM
snowblind7x
Jul 9, 2006 09:06 PM
Trooper
Jul 13, 2004 01:45 PM
