WHY DOES THIS HAPPEN????!?!?!?!
Old Mar 28, 2002 | 11:46 PM
IndiEp's Avatar
Default WHY DOES THIS HAPPEN????!?!?!?!
So, last night me and my friend were about to race a riced-out G2, and right when he was about to drop into third a noise happened, he pulled over thinking a flat tire, they were all in tact though, during idle the car sounded like a dual exhaust truck, air was "chugging" out of the valve cover, cops came, tow truck, BIG, LONG, messy story, anyways, he thought he blew a rod or something, today took off valve cover to discover a fricken spark plug blew up! i guess it was cracked nd moisture got into it, then detonated, causing us to lose miserbly, please explain if this sounds right. why would a spark plug make that much of a difference?!? the car could barely even idle, thanks for any input.
Old Mar 29, 2002 | 04:45 AM
GSRMatt's Avatar
25 Year Member
Default Re: WHY DOES THIS HAPPEN????!?!?!?! (IndiEp)
While I've never seen this happen, I guess everything's possible. Was it tightened properly?
If the plug was no longer intact the engine would have no compression and the a/f ratio would be way off. The pressure difference would screw up the flow to other cylinders as well, which explains why it ran so poorly.
I would replace all the plugs, and make sure the head didn't suffer any damage from parts of the plug.
Old Mar 29, 2002 | 05:59 AM
SpooN Man's Avatar
Default Re: WHY DOES THIS HAPPEN????!?!?!?! (GSRMatt)
if a plug goes bye bye, you will need to pull the head.
just try to start it with little chuncks in the chamber. LOL
Old Mar 29, 2002 | 06:53 AM
meept's Avatar
I've had something similar happen to a used motorcycle I just bought. Riding around the day after I got it, there was a loud pop and it started running very rough. Come to find out, a plug had been cross-threaded and blown out of the hole stripping the aluminum threads. A heli-coil later and I was back in business, but it's definitely something to check, especially on vehicles with aluminum heads and deep spark plug sockets.
Old Mar 29, 2002 | 06:58 AM
Jesse H's Avatar
Missing one plug, the motor is off balance. 3 cylinders have to take up the slack for that one and push thru the unburnt air/fuel mixture.
If sparkplug bits fell in the motor, the damage was already done when the car was limping badly.
Old Mar 29, 2002 | 09:38 AM
IndiEp's Avatar
Default Re: (Jesse H)
thanks everyone! yeah we took the head off, there was no pieces found in the block.....yet, but otherwise yeah, pulling EVERYTHING out, he's gonna get some new plugs/wires, hopefully it won't happen again! Thanks once again.
Old Mar 29, 2002 | 10:44 AM
hybridreams's Avatar
Default Re: (IndiEp)
Yeah happened to a guy I work with - overtightened the spark plugs
Old Mar 29, 2002 | 12:02 PM
GSR-REX's Avatar
New User
Something similar happened to my old car---a '91 Celica GTS. I accidentally overtightened a spark plug and stripped it out....but I didn't know it at the time. So I go to get on the expressway and start to get on the throttle then...BLAM...my spark plug shot out of the hole and almost went thru the hood!! It left a reverse dimple in the hood that I never did get fixed. Any way...lets just say that I now own a Torque wrench.....
salaamq
Dec 28, 2011 09:06 PM
pbink
Aug 22, 2005 07:26 PM
mongoliandonuts
Jul 7, 2004 09:10 AM
