Hay, Help With timing belt
Does anybody have a relatively detailed explanation on how to change the timing belt. It's almost due for my car to do the timing belt.
All Help appreciated
Cheers
Cheers
Here is an explanation of how to change the belt on a b18c1. It should give you an idea of what is involved in changing the belt on a dohc motor.
http://www.c-speedracing.com/howto/t...elt/tbelt.html
[Modified by 91civic, 12:09 AM 4/12/2002]
A H series timing belt is much different than a B series. I would strongly suggest getting a factory manual or having professional help. H series are a bitch when you have to try to figure things out without help.
changing the timing belt on prelude motors is a pain in the ***!! Its easier on b motors. You might be better off having someone do it for you. If you decide you wanna do it yourself get the book and good luck!!
JDMs1eeper
Jan 10, 2006 04:29 PM
