b20 help doing swap right now almost done
Old Apr 9, 2002 | 07:04 PM
1stealthls's Avatar
Default b20 help doing swap right now almost done
im helping my friend do his b20 swap in a 91 ls there is two sensors beside the oil filter one has a green plug the other has a rubber boot ( not the oil sending switch) what r these sensors also where do they go on the b20
i think the one with the green plug is the thermostat cooling switch
please help im in the middle of the swap right now that is all we have to do before putting it in please hel
Old Apr 10, 2002 | 12:06 AM
salbaje's Avatar
Default Re: b20 help doing swap right now almost done (1stealthls)
green plug is knock sensor and the other with boot is coolant temp. switch
Old Apr 10, 2002 | 01:16 AM
tinkerbell's Avatar
Default Re: b20 help doing swap right now almost done (salbaje)
(which is used to turn on the radiator fan)
Old Apr 10, 2002 | 04:47 AM
Speed PHreak's Avatar
The green plug is NOT a knock sensor. It's a oil pressure driven switch that works in conjunction with the speed sensiitive power steering that the 90-93 'tegs use. I've never hooked it up, never throws a code or causes a problem, just ignore it.
Old Apr 10, 2002 | 05:24 AM
SpooN Man's Avatar
Default Re: b20 help doing swap right now almost done (Speed PHreak)
then there should be three plugs back there. right ?
Old Apr 10, 2002 | 12:31 PM
Default Re: b20 help doing swap right now almost done (SpooN Man)
Right, you should have these:
A 1 prong oil pressure sensor
A 2 two prong coolant temp sensor
A Green plug for the other thing(don't worry about this one)
SLPN H
Jul 26, 2011 12:11 PM
chicows18
Jan 24, 2008 10:33 PM
1stealthls
Apr 11, 2002 01:51 AM
1stealthls
Apr 9, 2002 06:57 PM
