stock knock sensor and forged pistons...
Old Apr 9, 2002 | 09:31 PM
schwett's Avatar
New User
Default stock knock sensor and forged pistons...
short and sweet : will forged pistons in my h22 make the stock knock sensor (2000 lude) think i'm detonating and retard the timing?
Old Apr 10, 2002 | 05:34 AM
Mikey3000's Avatar
Default Re: stock knock sensor and forged pistons... (schwett)
no. you better resleeve the block if you want forged pistons though.
Old Apr 10, 2002 | 07:41 AM
schwett's Avatar
New User
Default Re: stock knock sensor and forged pistons... (Boss Hogg)
yeah, i was planning on that. sending the block to golden eagle for sleeving and decking, but i can't decide between arias 9.6:1 pistons (87.5 mm), je 9:1 (87mm) or je 9:1 (90mm) pistons. what's the increased likelihood of headgasket failure with the 90mm bore?
the arias pistons are cheaper....
Old Apr 10, 2002 | 07:53 AM
apexii's Avatar
How much do they want for the 9.6:1's? I am sending my block to them next week and I need pistons. The je's in 87mm are 9:1, I was thinking going a bit higher, we have 94octane everywhere.
Old Apr 10, 2002 | 08:13 AM
schwett's Avatar
New User
Default Re: stock knock sensor and forged pistons... (apexii)
are you boosting? i've only got 91 octane out here, so maybe 9:1 is the right thing to do...
ge has a "package," sleeving, decking, bore & hone, pistons, rings, and wrist pings for $1390. i assume that varies depending on motor, this is of course for an H22A4. same thing minus the pistons was $975. $400 bucks for the pistons, rings, and pins seems pretty cheap to me. je is more.
Old Apr 10, 2002 | 08:19 AM
schwett's Avatar
New User
while i'm at it, would it be worthwhile to throw in another $330 and get some eagle rods? only looking at 9psi of boost, around 250whp.
Old Apr 10, 2002 | 12:07 PM
Mikey3000's Avatar
if you're only going to boost 9 psi why even get forged pistons and resleeving? inline pro has an h22 turbo stock motor except for metal head gasket running like 18 psi (<<<not positive on that figure but it's up there). if you're going to boost more, and you have your mind set on getting forged slugs and resleeving, then you should go with the 87 mm pistons. you prolly won't get good life out of your head gasket with a 90 mm bore. yes while you're at it you might as well get rods.
Old Jun 19, 2002 | 01:22 PM
schwett's Avatar
New User
well, everything is back together and running, still breaking it in, but i am getting a MIL with code 0325 (knock sensor circuit malfunction.)
i assume that the sensor got broken in some rough handling when the block came out? or else the wives tales about stock obd2 knock sensors and forged internals are true.
Old Jun 19, 2002 | 03:28 PM
Ltech's Avatar
I don't think you need to spend all that money on 9 psi. Just my opinion.
jason phan
[Modified by Ltech, 4:29 PM 6/19/2002]
Old Jun 19, 2002 | 08:17 PM
schwett's Avatar
New User
Default Re: stock knock sensor and forged pistons... (Ltech)
did i ask? maybe you can tell that to the ±50% of boosted prelude owners (<10psi) who have broken their ring lands?
jason phan
Old Jun 19, 2002 | 10:47 PM
datspeed77's Avatar
I'm having the same problem on my car right now. I don't know if this is going to work, but I'm taking the knock sensor off of the block but leaving the wire connected. I'm trying to trick the sensor so it doesn't turn on my check engine light and retard my timing. They say you can lose up to 40-50 whp with the knock sensor retarding your timing. I'll let you know tommorrow if it works.
Old Jun 20, 2002 | 04:50 AM
Mikey3000's Avatar
what is a code 0325? is that an obd2 code or something? do you have the knock sensor hooked up? running to the correct ecm plug? i have je pistons and i don't get a knock code.
Old Jun 20, 2002 | 05:12 AM
apexii's Avatar
jason phan
Yes, and the truth is, it will cost a grip more to fix/replace a block should damage occur. I've spent more money fixing my bock than sleeving it.
Old Jun 20, 2002 | 06:56 AM
datspeed77's Avatar
It is an OBD-II code for faulty knock sensor.
Old Sep 16, 2002 | 07:57 AM
acura_typer's Avatar
Banned
Ok, so I am not the only one. I have a OBDI car I am currently having problems with. I have a Hondata chip installed, and I guess the codes are not there, but my check engine light comes on almost right away after I start the car. I have forged pistons installed. You can put a resistor to ground which is probably what I am going to do, instead of just leaving the sensor hanging there. I will research it more, let me know if you want to know the outcome.
Old Sep 16, 2002 | 08:42 AM
X2BOARD's Avatar
The K/S is affected by the forged piston slap on most pistons, particularly low silicone pistons like JE/Weisco. Your ECU may retard the timing on occasion, mistaking slap for knock.
If that's all you need to know.. there's your answer. It can happen.
hotimportcrx
Sep 15, 2005 10:13 PM
swteg
May 23, 2002 04:17 AM
BodyKits NW
Apr 11, 2002 08:54 PM
