Question B20 techs???
Old Apr 13, 2002 | 08:00 AM
1hottEG6's Avatar
Default Question B20 techs???
I have a b20 w/b16 head, i was wondering what kind of timing belt would be perfect to have on there. (i have an ls one on there but it is semi loose, plus the place where u can tighten the belt is maxed) i've been told too, to get a gs-r oil pump cause the crv one doesn't feed enough oil for vtec? thanks for ur help
Old Apr 13, 2002 | 11:03 AM
salbaje's Avatar
Default Re: Question B20 techs??? (B20eg)
if your using ls oilpump use ls belt. if gsr oil pump gsr belt. see what i mean??
Old Apr 13, 2002 | 11:47 AM
1hottEG6's Avatar
Default Re: Question B20 techs??? (salbaje)
will it hurt the eng. if i use the gs-r belt with crv oil pump?
Old Apr 13, 2002 | 12:32 PM
C1V1C's Avatar
don't use the crv oil pump, use a gsr one (it can handle revving higher), if you don't do this it will kill your engine!
Old Apr 13, 2002 | 03:02 PM
HBoy's Avatar
Default Re: Question B20 techs??? (C1V1C)
The belt matches the block. CRV/LS block = CRV/LS timing belt.
You only change the belt to a GSR when you use a GSR water pump, not the oil pump.
Old Apr 13, 2002 | 03:16 PM
andykatz1's Avatar
i sugjest doing it right the first time instead of crying about it later.... just get a gsr oil and water pump and use gsr timing belt....thats the safest route
Old Apr 13, 2002 | 04:33 PM
rainforest's Avatar
Default Re: Question B20 techs??? (andykatz1)
gsr and b20 oil pump same part number. and yes you just go by what water pump you have.
KdF
Mar 10, 2009 05:36 PM
beaneg6
Mar 10, 2009 04:08 AM
Dr.Octagon
Jun 12, 2006 07:42 AM
RTW DC2R
Jul 2, 2004 07:07 AM
gsrhatch22
Jul 3, 2002 04:22 AM
