obd 2 to obd1
Here are some benefits:
-No CEL associated with running a test pipe
-Easy and cheap to 'rechip' and run a better program
-Many choices for different programs to run
-No gay codes associated with running too rich/lean
-No gay cylinder misfire codes
-kenji
-kenji
I can make you an OBD2 to OBD1 ECU conversion harness. It is plug and play. Dozens of other Honda-Tech members are using my harnesses. Email me for more info.
-kenji
-kenji
I helped drop a 96 B18C1 engine into a 94 GS-R (already had OBD-1 harness and ECU). All we had to do was use the 94 distributor and swap the injector plugs on the 94 wiring harness.
