Tranny issues
Old Apr 10, 2002 | 03:47 PM
Qwikrex's Avatar
Default Tranny issues
Ok I just wanted to have an idea of how many people are having slight grinding under quick high RPM shifts? My tranny seems to crunch slightly on the 1-2 shift only when shifted quickly and at high RPM's. Anyone else have similar problems? Could it be from a worn out clutch? Or is it definately the synchro? And if it is a synchro, would it affect 1/4 mile times? BTW I have a B16A2 engine/tranny.
Old Apr 10, 2002 | 03:55 PM
fixhondas's Avatar
Default Re: Tranny issues ([VTEC]TL)
Sounds like a synchro- try some Honda MTF- it usually helps.
Old Apr 10, 2002 | 04:14 PM
Qwikrex's Avatar
Default Re: Tranny issues (fixhondas)
I've recenty changed with Honda MTF but it didn't make too much of a difference. If it is a synchro though will it affect 1/4 mile times or performance at all?
Old Apr 10, 2002 | 04:17 PM
fixhondas's Avatar
only if you can't get it into gear
Old Apr 10, 2002 | 07:15 PM
Qwikrex's Avatar
How much is it usually to replace a synchro?
Old Apr 15, 2002 | 09:14 AM
Vic Nyce's Avatar
happens in my GSR tranny on the 2-3 shift. only when shifting at high RPMs fast tho. i have 10W-30 motor oil in it. i've seen this really thick stiff from lucas racing that supposedly makes the oil cling to the gears. they had a little demonstration and it was pretty impressive. wonder how well it would hold up at higher RPMs tho.
Old Apr 15, 2002 | 11:22 AM
nfn15037's Avatar
Default Re: Tranny issues (Vic Nyce)
Gee, i wonder why it grinds with 10w-30?!? Try some Honda MTF and your grind will go away almost guaranteed. 10w-30 is designed for motors, not transmissions, which Honda MTF is designed for
Old Apr 15, 2002 | 11:26 AM
slowerthanu's Avatar
New User
Default Re: Tranny issues (nfn15037)
Actually, Honda used 10-w-30 before they released the MTF, which is basically 10-w-30 with some other ****.
Old Apr 15, 2002 | 11:50 AM
Regular Series's Avatar
Default Re: Tranny issues (slowerthanu)
The "other ****" being friction modifiers and whatnot that enable the tranny to function properly.
Old Apr 15, 2002 | 01:34 PM
fixhondas's Avatar
Default Re: Tranny issues (risingson77)
IF you want to replace the 1-2 synchros, be prepared to dig deep- They run around $300 for a D series.
mikej94civex
Mar 10, 2010 04:47 PM
-Championship-
Jun 29, 2006 12:37 AM
AMG
May 18, 2005 08:18 PM
TIRENECK
Dec 8, 2003 09:47 AM
RagingAngel
Nov 8, 2002 07:13 PM
