Problems with Webcam H22A inner springs contacting valve stem seals
The diameter of the inner springs is too small and thus will make contact with the valve stem seals. I have the Webcam valve spring/titanium retainers kit for an H22a. Is there something that maybe the machine shop did not do that is causing this or by any chance are the inner valve springs the incorrect ones?
Thanks,
Mark
Thanks,
Mark
Re: Problems with Webcam H22A inner springs contacting valve stem seals (se93)
Have you tried contacting web cams? It sounds like they sent you the wrong set.
Re: Problems with Webcam H22A inner springs contacting valve stem seals (RedlinedVTEC)
I just contacted them. They said the clearance between the inner valve springs and valve stem seals is very, very minimal. They said this is normal and won't cause any problems.
Mark
Mark
