B18A block and ITR clutch disc?
Depends on your tranny. If your tranny is a 90-91 then the input shaft is too small. If you have a 92-93 tranny you are okay.
Here are the specs
90-91 tranny: Shaft diameter 31/32"; Splines 24.
92-93 tranny: Shaft diameter 1 and 1/32"; Splines 24.
This means that the ITR disc will fit on the 90-91 but the hub on your disc will be stripparooney in no time.
Here are the specs
mike9571
Apr 15, 2007 10:02 AM
