tuning cam gears without dyno?
Old Apr 11, 2002 | 08:48 PM
kefka's Avatar
Default tuning cam gears without dyno?
i have heard of just making the adjustments then drive it and bring it back home and make more adj.'s if needed, any other opinions.?
Old Apr 11, 2002 | 10:46 PM
BoM's Avatar
BoM
Default Re: tuning cam gears without dyno? (circuitsports)
butt dyno which isn't close to accurate
or at the tracks, which is hard if you can't drive consistently
just start +1 intake -1 exhaust and play around little by little
Old Apr 13, 2002 | 12:36 PM
kefka's Avatar
Default Re: tuning cam gears without dyno? (BoM)
so when advancing one cam i need to retard the other?what happens if adjust both towards the positive?
[Modified by madeinjapan, 1:37 PM 4/13/2002]
Old Apr 13, 2002 | 04:35 PM
khoalie's Avatar
Default Re: tuning cam gears without dyno? (madeinjapan)
sorry to jack your post but what about single cams?
what the best setting in your experience.
i dont want to dyno i have no money.
my car just came with one and it is set on zero.
should i advance or retard?
Old Apr 15, 2002 | 07:42 PM
Quick 200k Mile Motor's Avatar
Default Re: tuning cam gears without dyno? (khoalie)
Advance.. quicker response, great drivability with the right amount. Make sure ignition timing is set properly (it will move when you change cam degree).
Retard.. shifts power to upper power band, but you can lose out on overall torque, & hp.
Freshdot
May 17, 2011 05:32 PM
b00stedbyFastrax
May 22, 2003 08:52 AM
-Whitey-
Oct 10, 2002 04:02 PM
WannAbe_DC5
Aug 27, 2002 07:15 PM
spankaveli
Jul 31, 2001 03:18 PM
