All b series starters the same?
Old Apr 9, 2002 | 09:22 AM
Jeff C's Avatar
Default All b series starters the same?
If not, what years are the same?
Old Apr 9, 2002 | 10:19 AM
AzG35's Avatar
Default Re: All b series starters the same? (Jeff C)
They should all be interchangable. The posts and terminals might not be in the exact spots, but they are there.
Old Apr 9, 2002 | 10:27 AM
sgT's Avatar
sgT
Default Re: All b series starters the same? (AzSi22)
if im not mistaken, all are the same but automatic
Old Apr 9, 2002 | 02:38 PM
Vracer111's Avatar
Default Re: All b series starters the same? (sgT)
Manual and Automatic starters are the same...When I did the auto to 5-speed swap on my GS I used the starter that was in the automatic tranny, as the Helms manual didn't say there was a transmission specific starter. Not sure on b16-b17-b18 starter interchangeability though....
[Modified by Vracer111, 5:40 PM 4/9/2002]
Old Apr 10, 2002 | 05:50 AM
SpooN Man's Avatar
Default Re: All b series starters the same? (Vracer111)
I think the jdm b16a's have a different flywheel tooth count. I think the starters are different. I could be wrong.
Old Apr 10, 2002 | 09:32 AM
Katman's Avatar
Default Re: All b series starters the same? (SpooN Man)
nope..that's bs. Whoever started that rumor needs to get shot in the face.
Old Apr 10, 2002 | 09:46 AM
CHEETAH's Avatar
Default Re: All b series starters the same? (Katman)
actually, some starters that fit the early cable tranny wont fit the later hydraulic.
Greg
Old Apr 10, 2002 | 11:23 AM
SpooN Man's Avatar
Good that makes replacement eaiser, I'm sure you know
Old Apr 10, 2002 | 01:15 PM
Jeff C's Avatar
Default Re: All b series starters the same? (CHEETAH)
cheetah,
When you say, "actually, some starters that fit the early cable tranny wont fit the later hydraulic," you mean they physically will not bolt up, right. It is not that the teeth counts are different because when someone purchases a flywheel, which I already have done, he/she purchases a "B series flywheel." I will be using a cable tranny, more than likely a y1, so I can just simply use a 90-93 integra starter, which should be easy to find, and everything will be peachy keen. Hopefully a tranny I buy will come with a starter though and I will not have to worry. Thanks guys for answering such a simple question. I have already messed up once and purchased the wrong clutch disc. There is just so many little things to know and I do not want to mess up again.
[Modified by Jeff C, 5:20 PM 4/10/2002]
acmoc
Dec 21, 2011 01:13 PM
tyler100
15
Jul 25, 2008 03:20 PM
Big Money D
Dec 12, 2005 09:01 PM
blykins
Feb 6, 2004 11:09 AM
Waachback
Jun 5, 2003 03:09 PM
