what sensor is his?
Old May 14, 2003 | 06:04 AM
tunes12's Avatar
Default what sensor is this?
Title should say this, not his. Anyway, It's a sensor located on the fuel rail. It has a vacuum line that goes directly into the intake manifold, it also has an electrical connection. I just found out that the plug doesn't even fit on it but I get no check engine lights or anything, but I want to know what it is. By the way this is a 99 Si engine into a 95 Si converted to OBD1 using gsr engine harness. Iwould post a pic but I haven't figured out how yet. Any help would be great, thanks in advance.
http://www.msnusers.com/mysong...oID=1
Modified by tunes12 at 10:51 AM 5/14/2003
Old May 14, 2003 | 06:57 AM
Chiovnidca's Avatar
Default Re: what sensor is this? (tunes12)
It's not a sensor. It's the purge control valve.
Old May 14, 2003 | 07:01 AM
tunes12's Avatar
Default Re: what sensor is this? (Chiovnidca)
Any idea as to what it does exactly? I figure it's not something that I should leave unplugged because it obviously sends an electrical signal somewhere.
Old May 14, 2003 | 07:06 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tunes12 &raquo;</TD></TR><TR><TD CLASS="quote">Any idea as to what it does exactly? I figure it's not something that I should leave unplugged because it obviously sends an electrical signal somewhere. </TD></TR></TABLE>
It's a solenoid valve. It receives the signal to purge the gas fumes in the canister.
jake00si
Jun 6, 2010 08:48 PM
lude22vti
Jul 10, 2007 04:12 AM
importlegions
Jan 27, 2005 01:51 PM
HXMan
Apr 20, 2003 05:17 PM
