vtec and the butterflies on a gsr..??
Old May 13, 2003 | 05:50 AM
92HB_HB's Avatar
Default vtec and the butterflies on a gsr..??
if your 2ndary butterflies don't open when you hit vtec on a gsr, you wont feel the vtec pull correct?? I think thats what happening to my car because when i'm in vtec, I can't feel it, but I can hear a change in the exhaust noise... i'm pretty sure all my wires are wired right because I have no codes.. I suspsect my problem lies in the routing of those darn vacuum lines that go into that little canister under the manifold.... have any of you guys experienced this??? or is it just me??
Old May 13, 2003 | 05:56 AM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: vtec and the butterflies on a gsr..?? (92HB_HB)
They shouldn't open when you hit VTEC, rather later on in the REV range. You won't be able to tell by ECU or codes. As far as I know they are vacum controlled. My friend had an H22A swap in an accord and his secondarys weren't working either and the dyno proved it. Leaky vacum line was the culpret.
90teg
Jan 5, 2006 03:09 PM
shyboi4u
Oct 7, 2005 11:54 PM
t_lager
Aug 5, 2005 02:54 PM
JdmFront619
Dec 23, 2003 10:48 PM
White S2k
11
Oct 30, 2002 11:07 PM
