Engine temp
Old May 15, 2003 | 11:28 AM
mrpeabody's Avatar
Default Engine temp
Ok I have a 92' EG6, stock, 100k miles, and it over heats. The needle climbs up when I drive it in stop and go traffic. when I get on the freeway the needle moves up and down as I drive. The temp is lower at high speeds, like 90+. I have changed the water pump, the thermostat, and the radiator(used but worked in the previuos car). What the hell. I need help....
Old May 15, 2003 | 11:46 AM
globlctzn's Avatar
Default Re: Engine temp (mrpeabody)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrpeabody &raquo;</TD></TR><TR><TD CLASS="quote">Ok I have a 92' EG6, stock, 100k miles, and it over heats. The needle climbs up when I drive it in stop and go traffic. when I get on the freeway the needle moves up and down as I drive. The temp is lower at high speeds, like 90+. I have changed the water pump, the thermostat, and the radiator(used but worked in the previuos car). What the hell. I need help.... </TD></TR></TABLE>
sounds like you have air in your system, your motor should have a bleeder on the motor on the neck that conects to your upper radiator hose. Unscrew it a bit untill coolent and/or air starts coming out. When its a steady stream of colent and no ait, your system is fully bleed.
Old May 15, 2003 | 12:01 PM
Darin D.'s Avatar
make sure your fan is coming on. you could also have a bad engine ground causing the gauge to fluctuate.
Old May 15, 2003 | 12:03 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Engine temp (Willis)
there is also the possibility of a blown headgasket. Drain your system, then start the car and if you see a steady stream of bubbles you have a blown headgasket....
Blaze
Old May 16, 2003 | 06:42 AM
mrpeabody's Avatar
Do I drain, refill, Bleed, and fill again? Also I notice that the water was brownish. The water bubbled up when I refill it after it overheated. I asume that the bubbles are from the overheating....
crazyguy
Nov 8, 2007 12:09 PM
fastcivicracer1
11
Jun 20, 2006 11:19 AM
88cerx
14
Mar 12, 2005 09:00 PM
Project X
May 5, 2003 11:28 AM
Jeff C
Apr 10, 2003 03:04 AM
