CTR cams/pistons in a zc
Old May 14, 2003 | 10:14 PM
89zchatch's Avatar
Default CTR cams/pistons in a zc
i was wondering if it was possible to put ctr(VTEC) cams or pistons in a zc motor(NON-VTEC) any help would be greatly appreciated :-)
Old May 14, 2003 | 11:17 PM
poison's Avatar
Default Re: CTR cams/pistons in a zc (89zchatch)
not happenin.
'nuff said.
Old May 15, 2003 | 12:46 AM
b18cx's Avatar
Default Re: CTR cams/pistons in a zc (poison)
uuummmmmmm, no. search, research.
Old May 15, 2003 | 03:10 AM
sparq's Avatar
I bet he never posts here again... lol !
Old May 16, 2003 | 05:09 PM
Spids5's Avatar
Don't judge or question
Yes u can...Why don't you do it and tell us how it works. Don't listen to the others they just don't want your car to be super fast. It will run atleast 12's with that set up. Let us know how it runs after your finished.
Old May 16, 2003 | 06:21 PM
blah13's Avatar
Default Re: (spids5)
Its possible but to use the ctr pistons you need the ctr rods, which have to fit on a ctr crankshaft which needs to fit inside a ctr block, then you need the ctr head for that perfect fit and some ctr stickers as well...er wait....
Old May 16, 2003 | 09:04 PM
InevitableRace's Avatar
Default Re: (blah13)
Sure you can put 81mm pistons in a Zc motor...Um you can get CTR style pistons for a zc in 81mm..They are JE pistons for a Toyota and the rist pin is the same size as a zc rod.Oh, I forgot about the block,This is what you do. Send the ZC motor to golden eagle and get it sleeved for 81 mm piston..and if anyone was smart they should calculate the bore 8.1x8.1x90/3.1416...If you do then you should get 1855cc...Umm is that bigger then a LS?? I think it is......
Thanks
Ross
Old May 17, 2003 | 12:27 PM
Default Re: (allmotrb18c1)
Im going to bump this one...
futureracecar
Feb 26, 2010 11:37 AM
JJBRADLEY
May 8, 2006 07:44 AM
THUNDERCHUNKY
Jul 20, 2005 11:59 AM
MikeMAN
Oct 17, 2002 11:39 PM
