PGM-FI Light
Old May 12, 2003 | 07:27 AM
wolfpack005's Avatar
Default PGM-FI Light
I have been having this problem for a while and I just want it to go away. I have an 86 accord lxi and I recently swapped engines due to a broken timing belt. the engines are the same. Before the engine swap the PGM-FI light would come on after about 10-20 minutes of driving the light would come on and whenever I come to a stop and the engine was at idle it would begin to lope. I ruled this as the EGR valve. Then the timing belt broke and I replaced the engine, the engine nolonger lopes, but the light is still coming on after about 20-30 minutes of driving. What could the problem be...HOW CAN I FIX THIS?
Old May 12, 2003 | 10:52 AM
1bad-eg's Avatar
Default Re: PGM-FI Light (wolfpack005)
Check to see if you have a loose connection somewhere and also check to see what the code is.
the95v6
Jun 13, 2016 04:56 PM
hondagall10
Aug 21, 2010 07:08 PM
Spartoons
Jul 9, 2007 05:44 PM
chirp2hrd
May 19, 2006 01:44 PM
MtbikingKing
Aug 25, 2005 05:42 PM
