obd0-obd1 trouble shooting ??
Old May 13, 2003 | 10:12 PM
spun Vtec's Avatar
Default obd0-obd1 trouble shooting ??
i did the convo useing a conversion harness it was made by a kid that i dont really think knows alot about the whole thing i wish i would have spent a little more and got it from blown90hatch because he could prob just tell me what to do and my car would fire right up but anyways.....
my dizzy is getting power. 12v to the black/yellow wire and it is getting ground (from the motor) but im not getting spark. whats the deal??
im getting a code 16 (one long blink a pause then 6 short blinks) which is fuel injector's everything is hooked up right on the injector's (pretty shure) and they are working i can hear then and smell gas
just no spark whats going on if its getting power should it be sparking?
Old May 14, 2003 | 12:35 AM
Kataku2K3's Avatar
Default Re: obd0-obd1 trouble shooting ?? (spun Vtec)
No code 4, 8, or 9 (CKP/TDC/CKP)??? I made a nonOBD-OBD1 jumper for my friend's Rex a couple months back and it worked fine... Did your motor run fine when it was nonOBD, or did you even run it??? I'm just double checking you here but since you're running an OBD1 ECU are you running an OBD1/2 distributor now??? The 16 is something wrong with your injectors but it could be a number of things... Everything in your jumper wired up correctly, atleast what you know of? Let me know, and i'll let you know if i think of anything else... Good Luck
Old May 14, 2003 | 08:32 AM
spun Vtec's Avatar
Default Re: obd0-obd1 trouble shooting ?? (Kataku2K3)
i have no idea if the dizzy is getting power should it be sparking unless there is somthing wrong with the dizzy?
Old May 14, 2003 | 08:37 AM
Kataku2K3's Avatar
In your first post you said that your distributor is getting power...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spun Vtec &raquo;</TD></TR><TR><TD CLASS="quote">my dizzy is getting power. 12v to the black/yellow wire and it is getting ground (from the motor) but im not getting spark. whats the deal??</TD></TR></TABLE>
Then you just said...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spun Vtec &raquo;</TD></TR><TR><TD CLASS="quote">i have no idea if the dizzy is getting power</TD></TR></TABLE>
Is it getting power?? If so and your ignitor is good you should have a spark... If all the sensors are wired up correctly and you have no codes then I'm wondering first if you're still running a nonOBD distributor (which fires at a different pulse rate than OBD1/2) or your ignitor is bad... Good Luck again
Old May 14, 2003 | 08:55 AM
omahaturbocivic's Avatar
The code 16 could be caused by just one of the injectors not wired properly. So you could be smelling gas but not all of the injectors may be working. If you get the spark problem figured out and it idles like crap start looking into that.
Old May 14, 2003 | 12:32 PM
spun Vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 &raquo;</TD></TR><TR><TD CLASS="quote">In your first post you said that your distributor is getting power...
Is it getting power?? If so and your ignitor is good you should have a spark... If all the sensors are wired up correctly and you have no codes then I'm wondering first if you're still running a nonOBD distributor (which fires at a different pulse rate than OBD1/2) or your ignitor is bad... Good Luck again</TD></TR></TABLE>
no i ment
i have no idea. If the dizzy is getting power why isnt it sparking???
im useing the obd1 dizzy
i was thinking that it might be the ignitor or the coil because its getting power to that black/yellow wire when key it to on position
Old May 14, 2003 | 12:33 PM
spun Vtec's Avatar
now in getting a code 41 o2 heater i know the o2 is hooked up wrong but it should still be gatting spark right?
Old May 14, 2003 | 02:59 PM
Quick 200k Mile Motor's Avatar
the o2 sensor must be hooked up correctly
Old May 14, 2003 | 04:47 PM
vtecrx's Avatar
Default Re: obd0-obd1 trouble shooting ?? (Quick 200k Mile Motor)
have you looked at your cap and rotor lately?
Old May 14, 2003 | 06:37 PM
spun Vtec's Avatar
Default Re: obd0-obd1 trouble shooting ?? (vtecrx)
yeah just got brand new cap and rotor yesterday and still no luck
no one has awsnered my simple question!!!
should a dizzy spark if its getting 12v power to the black/yellow wire and its grounded ???????????????????????
Old May 14, 2003 | 06:40 PM
Kataku2K3's Avatar
what do you mean the blk/yel wire is 12vdc hot but is grounded??? If it's grounded then you have a short... And YES, as long as the distributor has power and the ignitor/coil are good you should have a spark...
Old May 14, 2003 | 07:50 PM
spun Vtec's Avatar
the dizzy is grounded
and i have both so its safe to say its the dizzy thats fucked?
Old May 14, 2003 | 07:52 PM
spun Vtec's Avatar
if so ill just take it to napa and spend 100$ for a new one and not have to worry about it any more (warrienty)
Old May 16, 2003 | 11:18 PM
spun Vtec's Avatar
i duno i checked the coil today and the ignition control modual (icm) and the tests came out ok im still thinkin im gona try it on somone elses car (dist.) but i am lost on what to do im shure everything is wired right
larry
turbohatchBnuts
May 12, 2011 06:14 PM
91civicEX
15
Sep 3, 2003 10:33 PM
spun Vtec
May 14, 2003 12:37 PM
spun Vtec
May 14, 2003 08:34 AM
spun Vtec
May 14, 2003 08:33 AM
