Spun bearing questions
Everyone tells me this is probably what I did to my engine d16y8. I was running low on oil now I have a loud knock around 2500k. it still got me home.
I have a d15b7 block at the house that is my backup.
Its is possible for a backyard mechanic to fix this problem? I've checked out the hazone.com's tear down of the bottom end of the motor and it didnt look to bad. I have air tools to help my out.
Here are my ghey questions
1. Is the bearings that screwed up on the crankshaft?
2. How difficult is it to get to and replace?
3. Would my d15b7 bearings fit on this d16y8?
Nick
Nick
The bearing you spun is a rod bearing. It is on the crankshaft on the inside of the big end of the rod. There is a good chance that you scored the rod journal on the crank as well, so just thowing a new bearing on there won't be a permanent fix. You might as well rebuild the motor-all new gaskets and seals, bearings, thrust washers , piston rings, etc. Have the crank checked out and repaired at a machine shop. If this sounds like something you want to tackle, go for it.
another dumb questoin
if I just replace the rod bearing how long will that fix hold normally? Am I lookinging at loss of power or loss of reliablilty or what? I'm broke off my *** right now.
Is it just a waste of time to replace the rod bearing cause it wont make a week?
Nick
Nick
u could just take off the oil pan but the crank is prabobly damaged and as to be fixed this wont be a good thing unless u fix it the right way(take out the crank and get it fixed at a machine shop). Good Luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spun Vtec »</TD></TR><TR><TD CLASS="quote">rig it up and sell it
You are sooooo wrong for suggesting that. LOL I would be pissed if I got a rigged motor.
</TD></TR></TABLE>You are sooooo wrong for suggesting that. LOL I would be pissed if I got a rigged motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sinner »</TD></TR><TR><TD CLASS="quote">what kinda damage should I look for? scratches, scorn or what? </TD></TR></TABLE> u wont be able to see it with the naked eye but some of the metal on the crank will more than likely been scraped off and will cause some vibration if u just slap on some new barings. u would have to machine the crank down and get different size barrings, then ur engine will be good to go again. on the other hand u might just be better off buying another engine depending on what u have done to it and what kind of engine it is. Id say if its a stock engine with high miles throw that piece of crap away and get urself a new 1. good luck
ceearexx
Feb 4, 2014 05:31 PM
