DA tach going haywire
Old May 13, 2003 | 09:47 PM
brbHPR's Avatar
Default DA tach going haywire
just washed the engine on my 91 integra ls automatic, and first the cel light goes on. check the ecu, no codes. turn back on then the tach starts going haywire. what could be wrong?
Old May 15, 2003 | 10:23 AM
fourthgenhatchB17's Avatar
Default Re: DA tach going haywire (brbHPR)
u washed the motor?? I hope u covered ur distributor up and other wiring and didnt spray water over the top of the valve cover (cuz water fills up in the spark plug tubes). I would say u got moisture in something thats not suppost to have moisture in it. Under normal circumstances where no one has gotten water in anything, i heard the ignitor inside the distributor is the culprit. All u would need to do is get a new one.
Check spark plug tubes for water and open the distributor up to see if any got in there too.
Old May 15, 2003 | 10:42 AM
D-Man's Avatar
Default Re: DA tach going haywire (fourthgenhatchB17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 &raquo;</TD></TR><TR><TD CLASS="quote">i heard the ignitor inside the distributor is the culprit. </TD></TR></TABLE>
That's what it sounds like to me...ignitor time
DCcrx
Feb 12, 2014 04:20 AM
Gvis420
Nov 7, 2007 11:21 AM
Sinner
Mar 2, 2006 07:49 AM
crxcess
May 5, 2005 08:35 AM
katoeh2o
13
Apr 18, 2005 07:04 AM
