changing head gasket
Old May 12, 2003 | 10:45 PM
bey's Avatar
bey
Default changing head gasket
ok..my friend and I are gonna do my head gasket... what other stuff should we change out while doing the gasket... the motor is a d16z6 with a greddy turbo kit.. it has about 60miles on it... so far.. i was thinking about changing the timming belt and water pump.... what else can i do to it... thanks..
Old May 12, 2003 | 11:25 PM
civgrra's Avatar
Default Re: changing head gasket (bey_xiong)
full tune up parts would be a good place to start. plugs wires cap rotor filters, gaskets ( valve cover, intk mani., header, cam shaft seal, distributor shaft seal, ect)
Old May 13, 2003 | 09:36 PM
bey's Avatar
bey
so... i should change my intake gasket, header gasket,, and what is a cam shaft seal.. and what is a distributor shaft seal.... so ..if there is oil under my distributor, does that mean i should replace what ever gasket is leaking oil...
Old May 13, 2003 | 10:56 PM
MikeMAN's Avatar
Default Re: changing head gasket (civgrra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civgrra &raquo;</TD></TR><TR><TD CLASS="quote">full tune up parts would be a good place to start. plugs wires cap rotor filters, gaskets ( valve cover, intk mani., header, cam shaft seal, distributor shaft seal, ect)</TD></TR></TABLE>
unessesary. get a headgasket, timing belt and water pump. new head bolts would be good too. people have gotten away re-using them, but I wouldn't want to.
mike
Old May 14, 2003 | 04:12 AM
SupaFly_Honda's Avatar
put in a nuformz block guard
Old May 14, 2003 | 05:40 AM
88_SC_CRX_Si's Avatar
New User
Probably better off using a ARP Head Stud kit, especially with a turbo. They will pay for themselves, the next you have to pull the head....
Old May 15, 2003 | 02:12 PM
QCKGSR's Avatar
do a full tune up, you know a underbody light tune, led washers, foglight kit
Old May 15, 2003 | 05:38 PM
.RJ's Avatar
.RJ
Default Re: (bey_xiong)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bey_xiong &raquo;</TD></TR><TR><TD CLASS="quote">so... i should change my intake gasket, header gasket,, and what is a cam shaft seal.. and what is a distributor shaft seal.... so ..if there is oil under my distributor, does that mean i should replace what ever gasket is leaking oil...</TD></TR></TABLE>
http://www.helminc.com
Old May 16, 2003 | 10:48 PM
bey's Avatar
bey
ok..damm.. so far.. i got all the **** out.... the hardest part was the header bolts........ damm ...i'm never gonna use lock tight on that **** again....its gonna be a bitch trying to remeber all those hoses that go to the intake manny............ehh.. oh well.....
Old May 17, 2003 | 02:45 AM
EKFerioHawaii's Avatar
Also, how about brand new water hoses. All of them. New tensioner. And two brand new apple pie a'la modes.......dahhhhhh *slurp*
Old May 17, 2003 | 08:54 PM
3rdGteg's Avatar
Default Re: (EKFerioHawaii)
"Most Important"-----&gt;Check head and block for warpage while they are apart. Might need to get them decked/resurfaced.
Old May 18, 2003 | 10:02 PM
bey's Avatar
bey
warpage... what does that look like.... uhmm i'm gonna send my head into sam's to get it cleaned, resurface, and pressure tested.... bout $70... also.. when i took apart my turbo.... one of the gaskets was cracked... uhmm would greddy sell new gaskests or would it be better to buy a copper sheet from a parts store and make a template with the old one..??
BertDog
Mar 12, 2012 07:19 AM
doeboi365
37
Aug 24, 2008 07:19 PM
DCf4i
11
Jan 7, 2008 01:44 PM
B18C-VTI_R
Jul 13, 2004 01:23 PM
RTW DC2R
Sep 25, 2002 08:05 AM
