How exactly does VTEC work?
Old May 12, 2003 | 04:48 PM
dallasyoung's Avatar
Default How exactly does VTEC work?
Well what is the specific definition of VTEC? Please also define any big words lol. It the VVTi on toyotas the same?
Old May 12, 2003 | 05:05 PM
VTECorona's Avatar
Default Re: How exactly does VTEC work? (dallasyoung)
Valve Timing Electronic Control
Utilizing different cam lobes at different RPM's so the motor can be efficient yet powerful when needed. And yes VVTI is similar.
Pretty much allowing more air to get in the cylinders and to allow more exhaust gas out. Alas, more power.
http://www.howstuffworks.com will give you a more thorough explanation.
Old May 12, 2003 | 05:06 PM
deez92's Avatar
Default Re: How exactly does VTEC work? (97RedTegGSR)
Old May 12, 2003 | 05:08 PM
K20  EG's Avatar
Default Re: How exactly does VTEC work? (deez92)
there is a lil man that gets kicked in the ***...he turns on the schmegma valve to turn vtec on and off
Old May 12, 2003 | 05:40 PM
IN VTEC's Avatar
VVTi is more similar to MIVEC and VANOS than VTEC. Those systems have control over cam timing, but not lift. They can alter camshaft timing continuously over a given range (ie: +/- 50 degrees).
VTEC has control over lift and cam timing by switching b/w two different cam profiles (commonly referred to as the low cam and high cam), but it's not continuously variable like the aforementioned systems.
The newest generation of variable valve timing and lift control are VVTi-L and iVTEC. They are conceptually the same and both have continuously variable cam timing and two stage cam lobes for control of lift (and timing).
VTEC is ECU activated. The ECU determines when to switch cam lobes by taking input from ECT, TPS, and VTECOPS parameters.
Old May 12, 2003 | 05:43 PM
dfoxengr's Avatar
Default Re: How exactly does VTEC work? (IN VTEC)
well first your exhaust bearings are signalled by the rotary sensor... no seriously, howstuffworks.com is a great rescource for you...
Old May 12, 2003 | 08:12 PM
manolis's Avatar
iVTEC and VVTLi are combinations of a continuous variable valve timing system with a two or three steps variable valve lift system.
At http://www.pattakon.com you can see a new stepless VTEC system.
You like it or not, it can help understand the VTEC and VVTLi systems with animations and plots.
Thanks
Old May 12, 2003 | 08:25 PM
MikeSarr_GSR's Avatar
Default Re: How exactly does VTEC work? (manolis)
keep oil and it and it will work just fine
Old May 12, 2003 | 09:12 PM
sackdz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by manolis &raquo;</TD></TR><TR><TD CLASS="quote">iVTEC and VVTLi are combinations of a continuous variable valve timing system with a two or three steps variable valve lift system.
Thanks</TD></TR></TABLE>
Cool link
zxcv
Feb 11, 2004 05:48 PM
John
Dec 28, 2003 07:44 PM
S9 MECHA KARUMA
Jul 28, 2003 09:16 PM
tr4il
Nov 25, 2001 07:58 AM
