Spark plug question
Old May 12, 2003 | 05:07 PM
StinkyTofu's Avatar
Default Spark plug question
How often do people replace these? I have a mild n/a setup and have 2 years and rougly 17,600 miles on my stock plugs. Also, how do you know when you need to replace these?
Old May 12, 2003 | 05:31 PM
Chiovnidca's Avatar
Default Re: Spark plug question (StinkyTofu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StinkyTofu &raquo;</TD></TR><TR><TD CLASS="quote">How often do people replace these? I have a mild n/a setup and have 2 years and rougly 17,600 miles on my stock plugs. Also, how do you know when you need to replace these?</TD></TR></TABLE>
Honda recomends 2 years or 30,000 miles on most models. If they are platinum they go longer. What year and model do you have?
B-Tuning.com's Avatar
If you are using the copper plugs, just do it every few oil changes. It's only about $7 bucks.
Take a look at the plugs - if they are discolored, replace em... that's what I've always been told. I'd say 10-15K miles is a good plan if you don't want to replace as often as I do.
Old May 12, 2003 | 05:37 PM
t0p_sh0tta's Avatar
Default Re: Spark plug question (B-Tuning.com)
I change them every 3 or 4 months
Old May 12, 2003 | 05:43 PM
IN VTEC's Avatar
If the electrode if rounded off then I replace the copper plugs.
Old May 12, 2003 | 06:03 PM
StinkyTofu's Avatar
Default Re: Spark plug question (Chiovnidca)
I've got a GSR. Those come with platinum? Or do only ITR's come with platinum plugs? Thanks guys, i will check up on my spark plugs soon.
Old May 12, 2003 | 06:16 PM
IN VTEC's Avatar
Both come with the same platinum plugs. Different gaps.
Old May 12, 2003 | 06:54 PM
StinkyTofu's Avatar
Default Re: Spark plug question (IN VTEC)
Does compression have an effect on what type of plugs you need? I assume you would need to run a different heat, etc since temperatures will most likely be higher?
Old May 12, 2003 | 07:30 PM
IN VTEC's Avatar
You don't always need to switch to a colder plug or reduce the plug gap. Case-by-case basis.
Old May 12, 2003 | 07:38 PM
SpoonSportsJunkie's Avatar
Forgive me if you feel I am slightly highjacking your thread.. but this Q is important.. I could add that this subtopic could help your Q along too!
I have NGK plugs, stock # 6779 ... (bcpr6es-11)
they are copper, I am running a b series vtec w/ 11.3:1-11.5:1 compression. , type r cams, intake manifold, throttle bod, fuel system.
Has anyone used these model number of plugs in a similar scenereo???
I got them from Jdmhondaparts... (sheng) ... My mechanic didn't use them in my swap.. because he said that B series vtec should" have Platnum plugs! that Mine were the "wrong ones"
Old May 12, 2003 | 10:44 PM
StinkyTofu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">You don't always need to switch to a colder plug or reduce the plug gap. Case-by-case basis.</TD></TR></TABLE>
I see. How about the rate at which you change your plugs? Would that be effected, or would it still be the same as changing them the same time as if your motor were stock?
Old May 12, 2003 | 10:51 PM
sgT's Avatar
sgT
Default Re: Spark plug question (SpoonSportsJunkie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonSportsJunkie &raquo;</TD></TR><TR><TD CLASS="quote">My mechanic didn't use them in my swap.. because he said that B series vtec should" have Platnum plugs! that Mine were the "wrong ones" </TD></TR></TABLE>
Specifically, laser platinum plugs. NGK PFR6G-11 is what you should use.
For performance applications, you should change your plugs every 5000-7500 miles for optimal performance.
TypeRuz
Jun 11, 2014 08:28 AM
dongill
Dec 23, 2008 12:14 AM
FG_Coupe
Honda Civic (2006 - 2015)
Oct 26, 2007 05:29 PM
jdmspoonitr
Nov 9, 2002 06:26 PM
KF_S2000
Dec 3, 2001 07:42 PM
