Help with ITR big end bearings
Old May 13, 2003 | 02:34 AM
RICHJ's Avatar
Default Help with ITR big end bearings
OK My whole engine rebuild project has been stopped as I am having problems working out the right sized bearings.
All the conrods are stamped "25"
There are no letters on the crank where the manual indicates
the Honda manual also mentions bars, are these colour or number of dashs?
There are none where the manual indicates.
The crank has not been machined but the bearings are black and no colours can be made out on them.
I only have some faxes from honda of the manual pages, is there somewhere I can see these online incase I am missing something (i.e. like the info I need on the next page)
Honda are useless here, they have suggested buying a set of each and plastigauging the lot to find out which is correct, please help there must be a simpler way!!!
Old May 13, 2003 | 05:12 AM
94CivicSi's Avatar
Default Re: Help with ITR big end bearings (RICHJ)
I'd say go with the ACL's. They're "one size fits all". I just installed some in a B16, plastiguaged everything and they all wound up in the middle of the acceptable tolerances for new bearings. Research prior to my purchase found many happy users.
I got mine from Earl, both sets + thust washers. Send him a PM and see what kind of deal he's running for HT members now.
Old May 13, 2003 | 06:34 AM
RICHJ's Avatar
Default Re: Help with ITR big end bearings (94CivicSi)
I qould probably go that route, but I am in the UK and I wouldn't even know where to start looking for them over here.
Old May 13, 2003 | 07:55 AM
94CivicSi's Avatar
I'd PM Earl. If he's willing to ship FedEx Int., you're set. If not, maybe he could tell you if they're distributed in the UK.
Old May 13, 2003 | 09:23 AM
RICHJ's Avatar
Honda are going to take the crank away and check the sizes, I presume they are as puzzled as we are as to why there are not markings for the rod journal sizes.
Old May 13, 2003 | 09:36 AM
McFly's Avatar
Default Re: (RICHJ)
I think that the JDM ITR use those weird rods with that code on them. I work at a dealer and there isn't any rods with that code on them that I know of except JDM ITR rods. Mabye someone in Japan can help.
Old May 13, 2003 | 09:50 AM
RICHJ's Avatar
Could be right but as Honda are taking the crank to measure it all up they will be able to sell us the correct bearings.
You could be right about JDM as the UK engine B18C6 is pretty much the same as the JDM B18CSpecR engine (same compression etc... unlike US engine)
Modified by RICHJ at 8:49 AM 5/14/2003
Modified by RICHJ at 8:50 AM 5/14/2003
Old May 13, 2003 | 10:53 AM
sgT's Avatar
sgT
Default Re: (RICHJ)
i would have ordered a green set and measured against those.
Old May 13, 2003 | 10:55 AM
RICHJ's Avatar
Default Re: (sgT)
That is what I suggested, anyway Honda will pick up the crank tomorrow and will not be charging for any time spent on it
Old May 15, 2003 | 09:54 AM
RICHJ's Avatar
Default Re: (sgT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sgT &raquo;</TD></TR><TR><TD CLASS="quote">i would have ordered a green set and measured against those.</TD></TR></TABLE>
Just found out from Honda that Blue and Black are on back oder till mid Jun in UK so if any of mine turn out to be that I stuck.
Just a thought is it possible to have the journals machined to fit the bearings available? i.e. if I had a set of Green is it possible to get the journals machined to fit those with the correct clearances???
SnoopyMan
Nov 21, 2012 06:54 PM
N1 Andy
Apr 3, 2011 01:28 AM
94rster
Oct 20, 2010 11:41 AM
dgie
Jun 15, 2008 11:13 AM
importidiot
22
Feb 6, 2006 08:07 PM
